box bellows
so guys i find this material it was old fuirninture and i want to make box bellows with it i relaiser if i make bigger bellows waisting air in small hole wood"nt be important so i asking you how to make bellows to not ruin this material ;I need that this work
post-26717-0-63198700-1349021284_thumb.j
post-26717-0-63422800-1349021316_thumb.j
post-26717-0-41306000-1349021349_thumb.j
post-26717-0-26349100-1349021387_thumb.j
Make a sample from cardboard first. Then use the cardboard to transfer dimensions to the wood. Keep in mind the difference in thickness between cardboard and the wood
At SOFA last week I bought a box bellows I will try to take some lifts. It is double acting meaning it gives air on the push and pull. The plunged seal is made with feathers
great link rsw thanks for that.
Azur - click on the first link then click on the photos for more photos - dimensions are all there.
http://www.katanabuilders.com/katanablog/fuigo-box-bellows/
This link has the descriptions of building with more photos and with photos of building a forge that this box bellows is used with.
http://www.razoreye.net/mirror/charcoal-making/Box%20Bellows.htm
If this does not help you - please do some more searching yourself on the net...
Search "building a box bellows"
Azur - I forgot to put up the other link in the post before your last post - I have got both links in that post now (post#8).
thank you i will se what i can get with my material and by the way is the dimensions in milimeters
The water drum bellows is described in Harries and Heers "Basic Blacksmithing" about page 113
you can download a pdf here...well, I can at least...I don't know how well it will work in your part of the world.
http://www.webpal.or...ods/pioneer.htm
Any type of valve will require neat accurate cutting. Is there a friend of yours with some carpentry skills who can help?
Phil
Azur check this out
post-12950-0-77334900-1349140637_thumb.j
is this draw in inches or milimeter?
Looking at the file that's posted I would assume the measurements are metric.
can i use two bucket for water bellows i test it on small bellows it work good can i try with bucket about 10 liters
i make some bellows becazse i dont have leather i use a inner tube i dontknow is that good idea but here is picture
post-26717-0-33082300-1349264103_thumb.j
post-26717-0-01621400-1349264116_thumb.j
Azur
if it works then that is all that matters. it may not be the best material to use but try it and see what happens.
that is what this is all about. you may have great success with that material and you may not but so what.
it is part of this adventure you are on. if it works or dont then just reply back and tell us what happened. we can all give you
advice but unless you are willing to try it out then it really doesn't matter. there is nothing wrong with asking questions but you have
to be willing to accept the suggestions or even try them.
i said that i try with inner tube and dosent work i will try again with trapaulin or awning i will see what i get buy
