September 7, 201213 yr Hi all! If anyone is able to give me a possible idea of what kind of anvil this is, and the weight, that'd be fantastic. The dimensions are 20" X 9" X 7" Thanks! ~Rf
September 7, 201213 yr I think I found its twin, dimensions and all. http://www.ebay.com/itm/SHARP-102-lb-ENGLISH-BLACKSMITH-ANVIL-Forge-Iron-NO-RESERVE-/110948528116?pt=LH_DefaultDomain_0&hash=item19d50c2ff4
September 7, 201213 yr Have them put it on a bathroom scale. Weight from a few dimensions is iffy as the shape can differ so much---my longest, tallest anvil is over 100 pounds *lighter* than the next longest/tallest anvil as it's a slim late American pattern and the next longest is a squat pattern that is heavier through the waist horn and heel.
September 7, 201213 yr Author They say that it is 100lbs, which would match the one from MatchlessAntiques. Any idea of the maker? (I'd like to say that I can identify it, but I sadly am not THAT experienced.) Anyone wanna wager how high the MatchlessAntique's anvil will go for? :lol:
September 7, 201213 yr I'd take a close look at that one! It looks as though it might have a loose top plate right in the sweet spot! Looks like a crack about the middle on the near side and traveling over to the slag and then cutting to the left.
September 7, 201213 yr Author Are you talking about that seemingly triangular outline in the front half of the face? (towards the horn?) I have a chance to purchase this anvil for $100, but I might try talking him down a bit. If that is delamination, I'll skip on it.
September 7, 201213 yr I wouldn't skip it at a slightly lower price. You may work decades on it with no further issues and if not well you could always try to talk SOFA into doing another forge welding a face on an anvil demo...
September 7, 201213 yr The only thing I see wrong is the way the far edge dips down just past the hardy hole. Look at how wide it is at the yellow paint, and just as it passes the hardy, the line of the edge moves significantly. This could signify some serious radiusing on that edge for something they were regularly producing, or it could mean they had to grind back some major damage. Won't know until you get a look at the other side of the anvil. For a hundred bucks, though, I'd be hard-pressed to turn it down.
September 7, 201213 yr There is know way of knowing how much it weights there is no frame of reference. It is an old style English anvil from the mid 19th century. Its a bit sway backed with a bit of weld on the face (grind that off) and the edges could be better. I would buy that anvil all day long for 100 bucks. My anvil sense is telling me it is a bit heaver than 100 lbs perhaps 150. If they weigh it and it comes up bigger the price may go up. Don't dwell on it or hem and haw grab a C-note and put that anvil in your trunk. Its worth it. It does not looked cracked to me.
September 8, 201213 yr Gently tap the face with a hammer, if it sounds similar and solid everywhere give him the $100, load it up and be happy. If it sounds loose, tinny, or hollow in the questioned area then try to bargin a little. Phil
September 8, 201213 yr I have one a similar size to that and it weighs 62kg. So 100lbs for that one sounds about right to me. That anvil of mine is actually dead, it has a crack and no ring but that hasn't stopped it being a perfectly good anvil to work on. I only paid £10 for it and it's made that back a few times over ;) lol. Best of luck Andy
