Guiltyspark Posted September 1, 2012 Share Posted September 1, 2012 What do you think ? my first thing i forged Quote Link to comment Share on other sites More sharing options...
Perrin Aybarra Posted September 2, 2012 Share Posted September 2, 2012 seems pretty good for a first knife. but heck, what do I know? I haven't even done my first legit knife! maybe it's the angle, but it seems like the portion where blade meets handle is a little thin compared to the rest of the blade. Could you maybe get a direct overhead shot? Quote Link to comment Share on other sites More sharing options...
Whirly Posted September 2, 2012 Share Posted September 2, 2012 sparky, if that's the first thing you've ever forged, then good on ya Mate. I'd possibly reduce the 'hump' on your dropped point a bit. What did you make it out of? Look forward to seeing it cleaned up. You should have some of the knife Gurus/bladesmiths commenting and they'll give you good advice. Well done! Quote Link to comment Share on other sites More sharing options...
TheoRockNazz Posted September 4, 2012 Share Posted September 4, 2012 A darn good start! Perrin is right to ask for more pics, but it looks to be a safe width so long as it doesn't get skinny too. Props on the forging too, this is the first forge I've seen where the hammer used was actually dressed - or maybe you have really good control intuitively. I'm with Whirly in wanting to see that clip point brought back farther. What was the steel? What were you thinking for the handle? Quote Link to comment Share on other sites More sharing options...
Perrin Aybarra Posted September 5, 2012 Share Posted September 5, 2012 My bad, the thickness of the blade completely slipped my mind. Also, got any measurements on this blade? Just curious. Quote Link to comment Share on other sites More sharing options...
Loneforge Posted September 5, 2012 Share Posted September 5, 2012 Awesome first blade! Keep on it! Quote Link to comment Share on other sites More sharing options...
Guiltyspark Posted September 5, 2012 Author Share Posted September 5, 2012 My bad, the thickness of the blade completely slipped my mind. Also, got any measurements on this blade? Just curious.The length is around 15 inches the thickness is around a 1/4 inch . The steel is 5160 Quote Link to comment Share on other sites More sharing options...
Guiltyspark Posted September 5, 2012 Author Share Posted September 5, 2012 A darn good start! Perrin is right to ask for more pics, but it looks to be a safe width so long as it doesn't get skinny too. Props on the forging too, this is the first forge I've seen where the hammer used was actually dressed - or maybe you have really good control intuitively. I'm with Whirly in wanting to see that clip point brought back farther. What was the steel? What were you thinking for the handle?What does "dressed hammer" mean? Also i have more pictures coming , the steel was 5160. I ordered some micarta scales too. Quote Link to comment Share on other sites More sharing options...
TheoRockNazz Posted September 5, 2012 Share Posted September 5, 2012 Most blacksmithing hammers come with sharp-ish edges running around the face (if that makes sense) - grind these edges smooth so poorly aimed blows don't leave marks on the steel. Wow, spring steel was a good choice for this style blade. Temper the spine to a brown-purple (a little blue is fine too) with a propane torch after you grind/polish and harden it; repeat once more after a successful first time, but re-harden and start again if you go past blue. This'll give you a nice chopping tool - something to use for years to come. Quote Link to comment Share on other sites More sharing options...
Kwisatz Posted September 5, 2012 Share Posted September 5, 2012 Your first-born is always the best knife ever made! Quote Link to comment Share on other sites More sharing options...
Guiltyspark Posted September 6, 2012 Author Share Posted September 6, 2012 new pic Quote Link to comment Share on other sites More sharing options...
pkrankow Posted September 6, 2012 Share Posted September 6, 2012 You aparently have grinding skills. Looking good. Phil Quote Link to comment Share on other sites More sharing options...
Guiltyspark Posted September 6, 2012 Author Share Posted September 6, 2012 You aparently have grinding skills. Looking good. Philits hollow forged with grinding to remove some imperfections. I think i need a mushroom hardy because every time i would attempt to hollow it out it would flatten one side . Quote Link to comment Share on other sites More sharing options...
switchjv Posted September 6, 2012 Share Posted September 6, 2012 Wow! it came out great! Quote Link to comment Share on other sites More sharing options...
rockstar.esq Posted September 6, 2012 Share Posted September 6, 2012 Spark, I'm not sure if I understand correctly, are you trying to forge bevels that mimic hollow grinding? It seems like that'd be a harder way to go than flat forging bevels then hollow grinding them. Quote Link to comment Share on other sites More sharing options...
Guiltyspark Posted September 7, 2012 Author Share Posted September 7, 2012 Spark, I'm not sure if I understand correctly, are you trying to forge bevels that mimic hollow grinding? It seems like that'd be a harder way to go than flat forging bevels then hollow grinding them.no a "hollow forged" blade from my understanding is a very wide fuller (from edge to spine) that is forged in by hammer instead of ground by the profile of the grinder. think of it like the face of the blade being concave. Quote Link to comment Share on other sites More sharing options...
