August 29, 201213 yr The Peddinghaus I got is SO NICE and SO NEW I decided it needed it's own custom dedicated brand new stand, so I have been taking evenings and fabricating one. Kept it s the horn protrudes over the edge for extra free space when bending big things around it, plus extra stability over the 2 legs, Added a little tray for holding things like punches, lube can, chisels and rivets and stuff, with a hammer ring and a bending fork/tool holder out the other end. I would have liked to use something more substantial then 1/4" plate but that's what I had, hence the gusset, and figured I would ridgidize the whole thing with gussets all over. I want to add more tooling rings, and some made special for specific tools. I need to add some wood or perhaps some G10 slabs under the anvil to cushion things and also adjust the height perfectly, then figure out how I want to anchor it to the stand so as to be easily removed for transport, I want to do something cool and mechanical.
August 29, 201213 yr thats wicked sam! love how you decorated it - and the bending fork/tool holder and tray its all very cute and the anvil looks a treasure :) i ook forward to seeing your cool and mechanical anchor device... what/who is/are safety sally and what is she/they keeping that you dont want ? :)... i just really want to know that...
August 29, 201213 yr Very handy setup! Easy to beef up if you get some thicker plate like you wanted as well. If it even needs it.
August 30, 201213 yr Author Thanks!!! Dan, it should be easy to beef it up, but with the wood it should be fine. Beth a "Safety Sally" is a weak-ish, nervous type who is more obsessed with safety then with actually doing something, and feels compelled to comment to others about they're safety. Usually a step above "woobees" but a step below "armchair professionals" :D :D LOL They are different from those that actually care, and feel they are performing some sort of "duty" to someone. It was mentioned on another forum to use big wing nuts like Hofi makes and I think that is PERFECT.
August 30, 201213 yr I had not heard of the safety sally's. I am currently working at a site on my full time job and they are safety freaks, Way beyond practical safety, I won't go into the details but I dubbed them safety witches in my mind. They are working very hard to justify their existence and the management is supporting it. I had to have the plant electrician disconnect the power and it took him over an hour to mark out the work area and put up all the safety gear for a five minute job. A spotter to keep traffic away would have served the same function and would have saved them at least 45 minutes of labor. Oh well they are paying my company over 100 per hour to have me stand around I guess I can't complain.
August 30, 201213 yr ooh that is larvely. Excelent job. I'm not sure the wood will be enough. It will probably work but prolonged beatin on it may bow out the plate. As stated befor though, easy enough to reinforce.
August 30, 201213 yr what/who is/are safety sally and what is she/they keeping that you dont want ? :)... i just really want to know that... Here she is...........and she does mean well........ <_<
September 1, 201213 yr Nice work Sam! 3 legs is the future, even a 4 leg stand only really ever sits on 3 unevenly! I saw a hofi anvil on the 3 leg stand at a BABA event a few years ago and was very impressed at the simplicity, usability and stability of the design. Is (was) the anvil a virgin ? she looks a nice little lump!
September 1, 201213 yr Nice stand. My term for 'Safety Sally' is 'The Sphincter Police.' So worried about what they perceive to be unsafe conditions that they never actually get anything done. Absolutely NOT knocking safety. Just against taking it to such an extreme that you can't do anything without approval from a Senate Subcommitee.
September 2, 201213 yr Author MOBlacksmith, that's the types! Bionicarm, yeah might not be, can always beef it up or straighten it out then weld in more gussets :D John for sure!!! Well put, 4 legs makes things seem bigger too, which in my shop is nonono hehe. She is either a virgin or very lightly used, the fella I traded it to said it was his grampa's, and also that he had it blanchard ground top and bottom to so it has been resurfaced a bit. PE I like that hehe. Safety Sally's in my mind are the same but press they're "ideals" on others.
September 8, 201213 yr That's some good-looking work, Sam. I particularly like the near-vertical angle to the legs (idea officially stolen for the stand I'm making!). For securing the anvil, I'm opting for a threaded coupling nut (or regular nut) welded to the base and a beefy bolt that I've ground a shallow point on. The bolt bites into the base as it pushes the anvil back against a stop welded to the base. With a 2' breaker-bar, I can put some serious torque on that bolt!!
September 8, 201213 yr Author Thanks Vaughn! I like your idea for anchoring it down. Might steal it :D Hey did we just trade?
September 8, 201213 yr Sounds good to me, Sam! :D If you do go with the bolt idea, try to find a bolt that fits your truck's tire iron so you don't get to the demo and realize you left your socket set at the shop! Very embarrassing.....
