August 13, 201213 yr Author I know what the second thing was used for, but not what its name is. They were used during WWI to alert the allied troops of incoming posion gas. I think the second things some type of minnow or small insect trap. Possible bow weavel. I think the bottom tray like assembly is either for some type of photgraphic transfer, or possibly cheese making. I do not know anything nor do I have an idea of what the first and last picture are. The things star/rowel/4 point turns and clicks into place.
August 13, 201213 yr They were also used to scare birds out of grain fields and a variation is still sold as a party noisemaker.
August 13, 201213 yr The glass thing looks like my wife's wasp trap. You put sugary water in the bottom lip of the reservoir and cork the top. The wasps fly into the center hole, get trapped and drown. Perhaps the comb shaped thing is to hold hats by the brim?
August 13, 201213 yr the glass things look like insulators for the Elec. Co of old. the other looks like a conveyor thingy
August 13, 201213 yr i don't know what the first and last thing is but if I was still tying grain sacks I wiold use that to hold the sack while I tied them. It might be used to tie something that would otherwise come apart. Just a guess?
August 13, 201213 yr I googled and found on the French eBay a similar cast iron piece made by the same company. The seller says it is a billiard cue rack (holder), Napoleanic period.
August 16, 201213 yr The glass thing is a wasp trap. As someone else already mentioned, you put sugar water in the lower inside lip of the things and plug the top hole with a cork. The wasps fly up though the hole in the bottom but can't get back out and drown. Then you can pour everything out using the hole at the top. Cool stuff. Thanks for sharing the pics.
August 17, 201213 yr According to the book HARVESTS PAST (by Pat and Frances Patterson, photo on page 48) the wooden tray/roller device is a 'butter worker.' Used after churning the cream for butter and the draining of the buttermilk. The butter itself was scooped out of the churn, rinsed with cold water, then "...worked until all possible moisture has been pressed out." (Page 47 of HARVESTS PAST.) The rack for pool cues IMO looks right - one of those form follows function things. Lee Valley Tools here in Canada still sells a similar version of the glass wasp trap. And the rattle/noise maker has been explained (Thomas and Hayden.) I hadn't thought about use as a bird scare, did know about WWI use by Gas Senties in the trenches and during WWII by Air Raid Patrol (ARP) again for gas attack warnings in Great Britain (I still have my Grandma's cap badge somewhere.)
