July 29, 201213 yr ?? Folks awhile ago someone posted a link to a free program that automatically down size's you're LG PIC file from MY Pictures on XP to a smaller pic that can then be sent off to Ifi easier for viewing lol I bookmarked it for later use but now I can't find it :( anyone remember where it was or have a link to it ?? OR what it was ? Thanks Steve
July 29, 201213 yr In XP you can open Paint. Open Image. Go to Strech and skew. There is two small windows, Horizontal and vertical. Both indicate 100%, change 100% to 25%. Then save as JPG. If that is small enough you can go back and make the use 75% or whatever in both windows. That should do it.
July 29, 201213 yr There is one in Picasa when you export. Also here is a free one I have used for years. http://adionsoft.net/fastimageresize/
July 29, 201213 yr the on you are talking about is a power tool for win xp, http://download.cnet.com/Image-Resizer-Powertoy-for-Windows-XP/3000-18487_4-10905400.html this is a cnet link for downloading the program. I loved how simple it was but it's not offered on win7... hope that helps
August 1, 201213 yr I use this one a lot. http://www.faststone.org/FSResizerDetail.htm I do home and commercial inspection for a living and have taken just under 50,000 work related pictures in the last 7 years. I take 'em big for me to view, and shrink 'em small for sending to report writers and clients.
August 2, 201213 yr with Windows 7 all you need to do is right click on the pic you will see Edit #2 on the list it opens it up in paint #2 box at the header shows "Re-size" you can do 50 % or 75% and (save it ) you know the photo is the correct size when in paint it is only about a 4x5 it should load here . Sam
August 12, 201213 yr I'm going to check out some of these programs and see if one isn't easier to use than what I do now. I'm running XP and just right click and do a "Save As", it lets you pick the file size, I give it a new name and put it in a different folder for convenience. It's simple enough but takes a couple steps. Frosty The Lucky.
