June 19, 201214 yr This picture is all I have to go on- any guesses? They say 31" long, but no known weight or make.
June 19, 201214 yr Author I was wondering about that. Trying to get more info on it, but wondering it they installed a wood shroud over the waist or if it was an attempt at a fix.
June 19, 201214 yr I am going to guess there is close to 100# of anvil left. As long as it is solidly fastened that will work just fine. It is a fix, there are a number of documented anvils that fail at the waist weld, several others are posted here on IFI. They seem to be "newer" forged anvils, say early 20th century, when some companies transitioned to the lower half of the anvil being cast steel. This is based on other broken anvils that have been posted. I would put it to use and not think too hard about it. You have the working parts and they are in good shape. If you are buying/selling this anvil I would expect it to go cheaper, but well above scrap (say $1/lb, maybe less here in Ohio). Phil
June 19, 201214 yr The face and horn look great and I wouldn't hesitate to grab it up if the price was right.
June 20, 201214 yr One thing to check is to see if it "walked out in a lunch pail" if so it may not have been heat treated yet; so try the ball bearing test. If it's go and the price is appropriate go for it! My "wall of shame" has an anvil base, (Probably a PW according to Postman), missing the entire top section---but it's weight stamped so it once was a complete anvil. As stamping anvils was usually done towards the end of their forging an unstamped one might not have got that far...
June 20, 201214 yr One thing to check is to see if it "walked out in a lunch pail" One heck of a lunch pail! Phil
June 20, 201214 yr After I learned that one of the anvil manufacturers in Columbus OH had a row of completed anvils along side the steep river bank when they shut down I tracked down the location---just in case. None visible and the "river bed" was about 40% old steel bits. I did find a dozen or so old grindstones used to surface the anvil faces and rolled down into the river when they got too small (say 3' to 4' in diameter and 1' wide)
