February 20, 201214 yr Hi everyone, My name is Adam I'm 30 year old, I live in Poland in village near Wrocław. I work now like a simply welder method 135 MAG and 141 TIG inox steel (European standards). Now I want to start blacksmithing, because I like it. I have free spaces for workshop and need information how start it. I don't have anvil (yet), but I have blacksmith vise, some hammers, amateur welder machine with MMA (111) and TIG (141), simply locksmith table and a lot of enthusiasm. :D I want make chaep coke forge (build or weld), but I don't want use brake drums, I prefer plate or firebricks. I'm looking for advice and comments. I relly want to learn. I'm learn English (but few years ago) and I'm So sorry for any language mistakes (if you see, correct me). Greeatings prezesAdammm
February 20, 201214 yr Hi Adam, POWITALNY This is a great site to learn from. I would suggest you search the forums for ideas. There are many ways to build a forge. I am partial to Bran Brazeal's forge. But he uses a cast fire pot. (search for Roger Lorance) Anyway, welcome and have fun here. Bill BTW - your English is fine - the more you read here the better it will get.
February 20, 201214 yr Author Thx, Intresting forge, please for more informations; this forum is so big and I need links or topic word. :)
February 21, 201214 yr Welcome to IFI - good luck as you get started - search with the follwoing words: forge, firepot, super sucker, portable forge, coal, coke and tuyere. Links to follow- Tim
February 21, 201214 yr Go this link for "Show Me Your Forge" ... many good ideas!http://www.iforgeiron.com/topic/3836-show-me-your-forge-solid-fuel/
February 21, 201214 yr Author Wow, I need that, thx. Some this forges I can make now from steel scrap. Nice photos; in Poland we have a forum but for is to small informations and pictures and maiking tools plans; mayby small but for start useful. ;)
February 21, 201214 yr hi adam - good luck with building your forge - will wait to see pictures maybe! :) your english is great :)
February 21, 201214 yr Author Mayby in next day a take a photos my workshops and my tools, Forge I make when I have more time, now in Poland we have winter, and day is to short (in workshop 1 and 2 I don't have warming), and still work like a locksmith and welder. In good times I weld this elements: http://imageshack.us/g/401/gwpd.jpg/?fb_comment_id=fbc_384595838220207_5334475_384596434886814 Now I make road sings :( . But I stil want back to true welding... Mayby sometimes :P
February 21, 201214 yr welcome to IFI! Back in the days of yore at my old job I had more than a few guys form Poland working with me. That was before the Iron Curtain fell and most of them have now gone back now that Poland is free of control from Russia. So you have no anvil? To start with just about any large masive piece of steel will get you started so be on the lookout for one.
February 21, 201214 yr Welcome aboard Adam, glad to have you. A little searching on IFI will give you plenty of ideas and information about building most anything you need for a smithy. The one piece of advice I have for the anvil is don't get stuck on a particular shape, say london pattern, virtually any piece of steel with enough mass will make a fine anvil. One of the guys here used a coupling knuckle from a railroad car and I've used lots of different things. You write english just fine and I'm sure speak well too. Don't worry correct diction and eloqution aren't prerequisites for blacksmithing. Frosty The Lucky.
February 22, 201214 yr Author I see topic "Show me Your Forge" http://www.iforgeiro...rge-solid-fuel/ and I find First page post #11 forge mr. primtechsmith ( I have pan like that from pressure tank, because is nice cut this is good forge outside workshop :) ) second forge in workshop inside I want make like in post #74 mr. billp I make similiar from plans from polish blacksmiths forum: http://imageshack.us/g/201/palenisko.jpg/ I have weld part __/ by my forge is deeper with height 9 cm ( 1 '' is 2.5 cm), base 19 cm opens on 28 cm, I make hole on 3 cm but in this syttuation I dont have call on the pictures "grzybek" regulator air flow, but in post #74 are 2 pices rods welds in cross. I have weld pipies like a letter T 1''-| 2'' , up to the base my forge, down for noun I weld plate circle a and make from plate I make border I simly put this on pipe and I weld nut when I'm tighten the screw the pipe is closed. Pipe 1'' I need because this is size tube from old hoover (Polish production have two hole pull and push air) in cable I mont dimmer from light (my aunt have old in home buy new) and I have regulator flow (only I must set precission resistor - I'm end school like a assembler of electronics with proff title :D ). Some opinions and advice?
February 22, 201214 yr Author Second questions on forum are: Blacksmith Groups Forum I can join to some groups on this forum ? I don't see group from my country except neighbors from Ukraine. If I can who group for rookie like me you suggest? I want to have chances to learn. :D THX for next and before answers...
February 28, 201214 yr Author On Right side you have me (This big guy in blue :D ). This picture was made on the welding course method TIG. Year 2009 good old times. Simply call Adam... :blink:
March 7, 201214 yr Author My workshop: Front My first forge My second forge (not finish) for weld forge or brake drum First locksmiths table Second table this wood sheet I remove if I need more space Third wood table with blacsmith vise ( I make this in childhood when I must cut some wood plank) and still work :D Imitation of anvil :D My sweet loved hammers Some other stuff Magazine of screw, nuts, rivet and wood jam Proffesional blower with regullation (joke I know, but still work) Cheap, nice weld welder mashine My command center on the left side my proffesional dryer for rod, right PC I must have good music ;DIf I have problem with smoke I simply open this gates front and back and i have wind (this place was use to dry wood) My first hunting on junkyard (I'm wan't more...) And finally my biggest problem in my workshop, everything takes from here andI must go and look for the yard for my thing (speccialy gloves, smallest stuff) :D
