Grundsau Posted February 9, 2012 Share Posted February 9, 2012 I needed a solution to quickly make repetitive cold 90 degree angle bends in doubled 1/4" and 5/16" round stock. Saw this design elsewhere on the web and decided to make one for my P5 press. It really works, You can lower the top tool down to the 1/4" round stock, spin the flywheel and it bends with ease. The 5/16" round stock needs a little more oomph. I previously used a torch and jig to make these bends and will save on gas and time with the flypress. Allen Quote Link to comment Share on other sites More sharing options...
Randy Posted February 10, 2012 Share Posted February 10, 2012 Looks good! How about a shot or two of what you made with it? Quote Link to comment Share on other sites More sharing options...
pkrankow Posted February 10, 2012 Share Posted February 10, 2012 It is a small but beefy brake. If you put a couple screws in it for an adjustable fence (or even two of slightly different heights) you can then set up your station to do repetitive bending without as much repetitive measuring. Phil Quote Link to comment Share on other sites More sharing options...
Grundsau Posted February 11, 2012 Author Share Posted February 11, 2012 Hey Randy, are you going to PABA meeting tomorrow? Phil, good idea about the fence but I already have this heavy "key" that acts as a stop for the material. Looks like a shear key for some kind of heavy machinery. Have to figure out how to tighten up the ram adjustment. There is some small play in the ram when lowering it which causes the material to roll a bit. Allen Quote Link to comment Share on other sites More sharing options...
eric sprado Posted February 11, 2012 Share Posted February 11, 2012 Grundsau: You use the same tool inserts in your press as I do. I scored a bunch of short one inch bolts at a local recycling place and weld tools on to them. Already has built-in shoulder!!! Quote Link to comment Share on other sites More sharing options...
Grundsau Posted February 11, 2012 Author Share Posted February 11, 2012 That's a good deal! I went to a nearby farm equip dealer for mine. Would like to make a ring roller next but I'm not sure if there will be marks from the forming process. Quote Link to comment Share on other sites More sharing options...
eric sprado Posted February 20, 2012 Share Posted February 20, 2012 Grundsau: Or anybody else..I see your brake extends out from your press quite a bit. I need to bend some 5/16 by almost 3/4 the hard way in a radius to match the top of a fifty gallon drum. It goes about half way around the lid. I need to maybe weld some smaller angle iron to my jig to keep the metal going the hard way??? HELP!!!! Quote Link to comment Share on other sites More sharing options...
JNewman Posted February 20, 2012 Share Posted February 20, 2012 I made a jig for my flypress when I had one for bending flat bar the hard way. I took 2 pieces of 3/8" x2x3 angle iron I drilled holes through the wider flange. I then made two pieces of flatbar the thickness of the bar I wanted to bend with holes in them to match the ones in the angle iron and a radius on the end so the bar wouldn't get marked up. I then bolted the two angles together with the flats between them and some shimming so that the flatbar would move. This made a thin v block type tool that was adjustable for different stock. I had to grind a recess in the middle of the angles so there was room for the top bending tool to come down. Quote Link to comment Share on other sites More sharing options...
Grundsau Posted February 21, 2012 Author Share Posted February 21, 2012 JNewman, am I understanding that the bar slipped down between the flats while being formed and the flats helped to keep it from twisting? With that V-shape, did it actually close at the bottom? I have some 1/4" x 2" x 2" angle laying around. What if I took two pieces and drilled holes through both for bolts on the ends of the angle. Add two or more holes for 1" round bar to slip through. Then add a few washers to the bolts between the angle iron to match the width of the material being bent and bolt the angle together. A cutout would be needed for the top tool when its lowered. The material being bent would be supported by the angle as its "rides" on the round bars. Eric, what size press do you have? I have a P5 and have not tried anything like that yet. Are you able to bend it hot? Allen Quote Link to comment Share on other sites More sharing options...
John B Posted February 21, 2012 Share Posted February 21, 2012 JNewman, am I understanding that the bar slipped down between the flats while being formed and the flats helped to keep it from twisting? With that V-shape, did it actually close at the bottom? I have some 1/4" x 2" x 2" angle laying around. What if I took two pieces and drilled holes through both for bolts on the ends of the angle. Add two or more holes for 1" round bar to slip through. Then add a few washers to the bolts between the angle iron to match the width of the material being bent and bolt the angle together. A cutout would be needed for the top tool when its lowered. The material being bent would be supported by the angle as its "rides" on the round bars. Eric, what size press do you have? I have a P5 and have not tried anything like that yet. Are you able to bend it hot? Allen I am not Eric or JNewman, but yes that should work fine, I had a similar set up for putting a curve on 6mm (1/4") x 40mm (1.5") spring steel for forming rotavator blades stage 1 For the top tool I had a crescent shaped tool to stop indenting the workpiece, This set up also worked for bending up to right angles in square hollow tube, I used to make lantern/lighting supports with these so I could feed wires through the arms to reduce their visibility, The items had to have cable restraints and grommets fitted on finished assemblies to stop wires chafing. Info may come in useful some time in the future Quote Link to comment Share on other sites More sharing options...
Grundsau Posted February 21, 2012 Author Share Posted February 21, 2012 Thanks B) Quote Link to comment Share on other sites More sharing options...
JNewman Posted February 22, 2012 Share Posted February 22, 2012 No the bottom of the v was not closed and you are correct in how it worked. Washers should work to give you a nice radius, The only problem may be getting the thickness right. Quote Link to comment Share on other sites More sharing options...
eric sprado Posted February 22, 2012 Share Posted February 22, 2012 My press is small: a #3 but it should do the job. Whew: I'm re-reading these comments to try to figure out how you matched the tool with the desired radius! thanks guys!!! Eric S. Quote Link to comment Share on other sites More sharing options...
Grundsau Posted February 22, 2012 Author Share Posted February 22, 2012 Thanx John. Eric, If you don't mind, post some photos of how things worked out. Quote Link to comment Share on other sites More sharing options...
eric sprado Posted February 27, 2012 Share Posted February 27, 2012 I wound up making a slotted radius jig for my Harbor Freight bender Works GREAT: Quote Link to comment Share on other sites More sharing options...
