waianvil Posted December 10, 2006 Share Posted December 10, 2006 Need help on welding what electrode to use on welding having trouble on what to use been away to long from it need help Quote Link to comment Share on other sites More sharing options...
Rick Barter Posted December 10, 2006 Share Posted December 10, 2006 You might try the Miller web site. They have this calculator tool there.http://millerwelds.com/education/calculators/stick_amperage_calculator.php I hope this helps. Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 10, 2006 Share Posted December 10, 2006 You'll need to be more specific for us to help. Frosty Quote Link to comment Share on other sites More sharing options...
Glenn Posted December 10, 2006 Share Posted December 10, 2006 Give us specifics on what you are doing. The more specific, the more assistance you can get from the welders here.Blueprint BP0052 AWS Welding Rod Classification is a place to start. Quote Link to comment Share on other sites More sharing options...
waianvil Posted December 10, 2006 Author Share Posted December 10, 2006 The site that rick help me a lot, was just welding mild steel,1/8 inch thick I just was not getting a good weld looked like a pile of mess, also what is different between argon and moongone gas.thank you gerald Quote Link to comment Share on other sites More sharing options...
Mr Smith Posted December 10, 2006 Share Posted December 10, 2006 Yeah... 1/8th... wind down the amperage a bit. Either that. or switch to MIG. Argon is a noble, or unreactive gas. That is the reason why it is used as a shielding gas. It displaces oxygen. As for moongone gas, I have no idea. Can any moon men help us out? :) Quote Link to comment Share on other sites More sharing options...
irnsrgn Posted December 10, 2006 Share Posted December 10, 2006 Argon is an inert gas, which means it does not react with anything, and its 2.5 times heavier than air. Never been to the moon,LOL. Moon gas is more than likely a trade name for a mixed gas. Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 11, 2006 Share Posted December 11, 2006 Argon isn't the best shielding gs to use on mild steel. 75/25 75% argon 25% CO2 works a lot better. Now, I don't want to hurt your feelings but you really should learn to weld before you start using a mig welder. Migs are known as the Lawyer's welder for a good reason. It's really easy to make a pretty LOOKING weld and have one side cold lapped, no penetration. A cold lapped weld will fail as soon as stress is put on it. I recommend finding a community college with a welding course. They'll start you out O/A welding which will teach you the necessary basics. You can't make good welds without knowing what a puddle is, how to get equal penetration, how to control the puddle, how and when to fill the puddle and so on. As you may have guessed a proper puddle is essential. The problem with a mig welder is it fills the puddle almost as fast as it makes it, in fact it will fill without a puddle at all. This is a cold lap and has won many a lawyer a good living in court. I don't intend to discourage you but I don't want to see you put something together only to have it come apart at a bad time. I don't have so many friends I can afford to let one get hurt if I can help it. Frosty Quote Link to comment Share on other sites More sharing options...
Ten Hammers Posted December 11, 2006 Share Posted December 11, 2006 Not meaning to be contraversial but I use 75/25 argon/c02 in the shop here. We use 95/5 ( Argon/02 ) at work for mild. The gasses will make the puddle freeze at different rates along with the adjustments on ( and sometimes inside ) the welder. 100 % argon I use for TIG. Moon gas must be a trade name like Tri mix or Stargon, I've never heard of it ( but lotta things I've never heard of either ). As has been mentined, training is the key. A good CLEAN lens of the proper shade will allow you to watch whats happening. Would appear from your posts that you are using stick. What kind of welder and setup are you using ? Dry electrodes make a major difference. Quote Link to comment Share on other sites More sharing options...
