basher Posted January 12, 2011 Share Posted January 12, 2011 Had a spring go on my goliath 60lb hammer today . very un traumatic .I noticed that the hammer was "slapping" a little and the dies were now touching . there was a slight change of sound . cut the leather off of one side and behold a broken spring . I have had 3 springs break on the 3 different mechanicals I have had ( two 60's and a 150lb ), they have all been origional springs (i think) . all of them were enclosed in a leather sheath to prevent the spring escaping in a case of breakage . This method works very very well I would recommend it .It may be that the LG springs are under a lot more force . Anyhow I have sent the broken spring off for re making and should have it back in a week . replacement springs are £110 a pair which in this day and age is pretty good . I am glad that you can still get custom springs in the UK. Quote Link to comment Share on other sites More sharing options...
eric sprado Posted January 12, 2011 Share Posted January 12, 2011 Good idea. How thick leather are you using. Never broke one,but it always makes me nervous to think about it.Eric Sprado Quote Link to comment Share on other sites More sharing options...
brian.pierson Posted January 12, 2011 Share Posted January 12, 2011 Basher, bad luck but good you can replace it. Do you have a picture of the leather covering? I just got a LG 25 and it needs a shield to stop any flying metal in case of spring break. I would like some thing that doesn't get in the way so I am curious on how it looks. Brian Pierson Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted January 13, 2011 Share Posted January 13, 2011 Seems a little early for "Spring Break"! Quote Link to comment Share on other sites More sharing options...
brian.pierson Posted January 13, 2011 Share Posted January 13, 2011 you know what they say "hope springs eternal" Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted January 13, 2011 Share Posted January 13, 2011 Nuts, I thought this was going to be about co-eds frolicking about using something called Goliath power hammer. Hmmm sounds like a new energy drink name. Quote Link to comment Share on other sites More sharing options...
Bob S Posted January 13, 2011 Share Posted January 13, 2011 Basher, bad luck but good you can replace it. Do you have a picture of the leather covering? I just got a LG 25 and it needs a shield to stop any flying metal in case of spring break. I would like some thing that doesn't get in the way so I am curious on how it looks. Brian Pierson I like this guard. I got the pics from the forgemagic site. Originally posted by Tio Pick. Bob Quote Link to comment Share on other sites More sharing options...
basher Posted January 13, 2011 Author Share Posted January 13, 2011 here are the spring guards on my herculies 150 they are sewn and bolted through the leather . the goliath has guards that were also bolted into the throwing arms . Quote Link to comment Share on other sites More sharing options...
basher Posted January 13, 2011 Author Share Posted January 13, 2011 leather is 5mm... 200 thou Quote Link to comment Share on other sites More sharing options...
brian.pierson Posted January 14, 2011 Share Posted January 14, 2011 Basher, thanks for the picture. Bob S, thanks for the pictures. You posted those for me when I was asking and I didn't reply. My apologies. I have my hammer now so I have to build a house for it this spring. Once that is done then the shield. I may combine the two. I will have to see what kind of clearance I will have. Brian Pierson Quote Link to comment Share on other sites More sharing options...
Mainely,Bob Posted January 14, 2011 Share Posted January 14, 2011 One of the ways we would guard springs in some of the machinery we ran was to find a piece of hose with an ID that allowed it to just slide over the spring and cut it to fit the application.Hydraulic hose is reinforced so it should contain just about anything a sheet metal guard will.You can cut reinforced hose with a cut off saw,I`d do it outside though.It makes lots of thick nasty smoke. Quote Link to comment Share on other sites More sharing options...
OldGit Posted August 8, 2019 Share Posted August 8, 2019 Hi Basher could you give me the name of the custom spring manufacture. cheers Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted August 8, 2019 Share Posted August 8, 2019 Welcome to IFI OldGit. Have you read this yet? READ THIS FIRST Editing your profile to show your location will help with reply's. Quote Link to comment Share on other sites More sharing options...
basher Posted August 9, 2019 Author Share Posted August 9, 2019 19 hours ago, OldGit said: Hi Basher could you give me the name of the custom spring manufacture. cheers I am afraid that I no longer have records for the 2 spring manufacturers I used one in St Ives and one in NE London. both were prompt and did good work. there are lots of them around though I would just do a search... Quote Link to comment Share on other sites More sharing options...
