November 9, 200619 yr Back to the topic at hand. Why is there a hole in the lower section of the tool? Was it simply how it worked out or did you add that later as a self cleaner for the scale?
November 9, 200619 yr Author What's been done on this one is that the hole has been drilled, then the top part hammered in. That's just another way of doing it, it'll keep the ball in the right place, when you hammer it down I s'pose. I'd say there are many ways of depriving a feline of its epidermis! :)
February 29, 200818 yr Just browsing around & found this great thread. I really like the jig, good idea! fwiw over here we have a sizable history of very small spoons, usually silver, for salt & pepper. Not 'cos it was expensive (we're talking 17-1800's here), but 'cos you don't want much of it on your food. ;)
June 28, 200817 yr Small spoons would've been used extensively for measuring spices. never heard of a teaspoon? 1/8th of a teaspoon measurements are common in many dishes, and from the looks of things those little spoons would be perfect for it. And besides, why whittle a piece of bone with a razor sharp knife when it could splinter and ruin your hands day? Only takes 2 minutes to make the spoon. The nobles might've used bone, but silver was easier and you can use a horn as a cup to hold water
July 4, 200817 yr I sell them as salt spoons,in the 1700's salt was expensive and it was kept in a salt cellar a small square glass or silver box with a lid. The jig I use is a spring swedge the base is a rivit set that fits the pritchel hole with a ball bearing welded on the upper side.
November 8, 200817 yr I just saw this thread and I think this is a very neat item to sell at shows. If you don't mind I am going to build a copy of your jig. People love a story with any Item they purchase. I sometimes make up very elaborate "Tales" to go along with an item. Most people know right away that it's BS but love the whole idea.
December 4, 200817 yr I just found this thread, and for one, like the idea of something small that can be forged while people are watching!! Think people are getting tired of watching "S" hooks being made!
December 11, 200817 yr I used to cast a small bronze spoon and a silver one until I found out what they were being used for. It was the same thing that the little coffee spoon from McDonald's was being used for. They took the bowl off of their spoon to stop folks from using it to measure banned substances. That little forged spoon looks to be just about the right size to measure that dastardly white powder with.:cool:
December 11, 200817 yr I made a few and gave them away. One of my friends took it off his keyring because of what people might think. From now on, I'm making horseshoe nail forks!
March 19, 200917 yr Made four of these little horseshoe nail spoons, I used #16 nails and made them a little larger, now all i have to do is figure out how to post pictures/Selden
May 24, 201313 yr I have a few questions being that I am a fledgling blacksmith. DO you do the twists and loops before you shape the bowl or after? What size hammer do you use do bend such a small item? I think my 2 pounders might be a bit much. Also aren't the nails zinc plated? DO you have to worry about fumes or are they too small to make much? I have 2 huge boxes of horseshoe nails in my forge and I would love to make these to sell in the gift shop. They are BIG nails too although I don't know what size they are. I'd say 3 inches long with a 3/16 x 1/2 in head. Would these work? How do I make a loop that small? I only know how to make a loop on the horn of my anvil so far. Any help would be appreciated!
June 2, 201313 yr I'd do the twist and loop after the bowl. The little "loop" is easy. Just let the tip of the nail protrude a little over the far edge of the anvil, and kind of "brush" it with the hammer to start the bend downwards. Push it out a little more and do it again. Then flip the loop so it points upwards and tap it with the hammer towards you while you raise the tongs. Making a loop like that is easy-just don't hit the same place twice. If it'll help I can post some pics for you. If you have a couple boxes of nails, you'll get good at them quickly. If you don't have the stuff to make that jig, you can just make a round hand held punch and use a block of wood-just set the nail on a block of wood and drive it down with the round punch. If you soak the block of wood in water it'll smoke less.
June 2, 201313 yr Forgot to add, I'd do the loop first, then twist. When you heat for the twist, dip the loop in water to cool-you can then grab it with the tongs to twist it and not damage the loop. But, that's how I'd do it-there is many other ways, I'm sure.
June 2, 201313 yr You could use a carriage bolt for your dome and it could all be made from your strap, you can weld a piece of the strap at a forty five angle to fit your hardy hole. I am seeing another use for my doming block set. Instead of welding a dome or ball bearing on the top, you could drill a hole to fit different size doming punches. The harbor freight doming block set is cheap and the shanks ar so short they suck to hold. Kill two birds with one stone.
June 7, 201312 yr Thanks for sharing, a great idea!! I think this would be a nice work for me to show the visitors in the museum in our town. Peter (I hope, you permit it to me)
October 13, 201312 yr thanks for all the info I'm going to build one of these jigs and make spoons for family and friends besides the wife likes them and has thoughts for them also
