plain ol Bill Posted September 12, 2010 Share Posted September 12, 2010 I am building a new gas forge w/ a ribbon burner. I want to put some good doors on it front and rear rather than just blocking with fire brick. How did you do your doors?? :huh: Quote Link to comment Share on other sites More sharing options...
edge9001 Posted September 12, 2010 Share Posted September 12, 2010 here is the doors on mine... open and closed to give you an idea of the design. I find it works very well only with the depth of the chamber I've found I need a brick floor to raise the work up to the opening. I will probably make a few changes to it in the future. Quote Link to comment Share on other sites More sharing options...
Frosty Posted September 12, 2010 Share Posted September 12, 2010 I use fire brick instead of doors. Heck, you couldn't put doors on my gasser and keep it's practical aspects. It's a variable geometry/volume design you can shange the size and shape of the chambers as necessary. Frosty the Lucky. Quote Link to comment Share on other sites More sharing options...
Sweany Posted September 13, 2010 Share Posted September 13, 2010 http://farwestforge.com/Forum/bsgview.php?photo=3280&cat=&by=Sweany The door doesn't close the forge completely, it leaves about 2" open for small stuff, open the door for larger items.... Quote Link to comment Share on other sites More sharing options...
Mainely,Bob Posted September 13, 2010 Share Posted September 13, 2010 Thanks for the link Sweany. I bookmarked it as there is a ton of stuff I can use on it to include all those really great scaled down gas forges.You are one REALLY inventive guy! Thanks for posting and inspiring me. Quote Link to comment Share on other sites More sharing options...
Pat Roy Posted September 14, 2010 Share Posted September 14, 2010 When I saw the title of this thread, I thought we were talking about "Doors". This is one of mine, still not hung. Quote Link to comment Share on other sites More sharing options...
petere76 Posted September 14, 2010 Share Posted September 14, 2010 Pat, Nice job on that door, looks great. Quote Link to comment Share on other sites More sharing options...
chyancarrek Posted September 14, 2010 Share Posted September 14, 2010 Ditto to Frosty here - I've got a variable volume gasser that just uses bricks stacked in different configurations Quote Link to comment Share on other sites More sharing options...
Frosty Posted September 14, 2010 Share Posted September 14, 2010 Ditto to Frosty here - I've got a variable volume gasser that just uses bricks stacked in different configurations Basically the same thing I built if you put the lid on a jack. I do recommend a trailer jack though, I used the scissor jack because I had it. Frosty the Lucky. Quote Link to comment Share on other sites More sharing options...
chyancarrek Posted September 14, 2010 Share Posted September 14, 2010 Basically the same thing I built if you put the lid on a jack. Frosty the Lucky. Frosty Yeah, I wish I'd seen your design before I built mine . . . I like yours better - more "makes sense" in my mind I copied mine from a design I saw at Ponderosa Forge in Sisters Or. Mine's supposed to have a counter-weighted cantilever set up to raise and lower it but I got as far as you see in the pic then put it to work - someday I'll finish it up! Ok, Ok, I'm done with my thread hijack . . . back to our regularly scheduled programming . . . Quote Link to comment Share on other sites More sharing options...
Dave Hammer Posted September 15, 2010 Share Posted September 15, 2010 I've made several forges with moving metal (some lined, some not) doors. Seemed like a good idea at the time. The problem I had was that, over time, the heat would warp, and/or deteriorate them. I choose to use firebrick to keep this from happening. I also need to be able to move my forge out of the way easily. These photos show the method I use today on my forges. 3 inch channel iron, welded on the end of the forge. It allows me to put the forge on a pedestal and easily move it... Soft brick is EASILY cut with a hand saw of any type. Quote Link to comment Share on other sites More sharing options...
Mainely,Bob Posted September 15, 2010 Share Posted September 15, 2010 Sweet lookin` forge there Dave. Simple,straightforward design and it looks to be very versatile. I have the pics bookmarked for future use.Thanks for posting them. PS-what does the base look like? Quote Link to comment Share on other sites More sharing options...
