mrkiddi Posted September 6, 2010 Share Posted September 6, 2010 hello:) i have here three parts i would like to use for a forge but i have never made one before. so i want to be certain i can use one these or if i have to continue my search:) Quote Link to comment Share on other sites More sharing options...
edge9001 Posted September 6, 2010 Share Posted September 6, 2010 the channel piece might work well, but IMHO the rotor and drum you have there, with the hub being part of the rotor and drum, are not so good. I would suggest a brake drum from a car, or just start with plate steel and weld together a firepot and table. Quote Link to comment Share on other sites More sharing options...
pete46 Posted September 7, 2010 Share Posted September 7, 2010 Use an old or new wheelbarrow . Cut a hole in the bottom or side[for a side draft forge]. Then put in pipe & cover w/sand or clay. Hope this helps! Quote Link to comment Share on other sites More sharing options...
TimB Posted October 9, 2010 Share Posted October 9, 2010 Here's a picture of mine that might spark an idea for you. Since propane tanks are a dime a dozen now since the valve type changed here in the states, (or, like me you had a few laying around anyways). I unscrewed the valve and screwed in a 3/4" nipple, (I'm using compressed air) , but the next one I try, I may cut a 2" hole and use a blower--high velocity / low psi air. Quote Link to comment Share on other sites More sharing options...
aquamanlr Posted October 9, 2010 Share Posted October 9, 2010 Here is what I put together from a propane bottle ( SAFETY FIRST ). I used adobe. LeeRoy Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 9, 2010 Share Posted October 9, 2010 I'd put the channel in my stock section for later use. The disk rotor might be okay but the truck drum is just too big, especially if you're just starting out. check out Glenn's 55 forge, it's based on a 55gl drum and doesn't take much for tools to make and works quite well. A forge can be as simple as a hole in the ground, be careful to dig to mineral soil if you go this route. You can use a wooden table with a few inches of clayish soil compacted on it. The blast doesn't have to come up from the bottom (called a bottom blast) but can come from the side (side blast) and works much better with a wooden forge frame because it lets the dirt, clay, adobe, whatever protect the wood without a break. With a little imagination you can make a bellows from a cardboard box and a little tape. Then a piece of pipe to the forge table and you're ready to go. Using the air hose for the blast will work but tends to have too little volume (cfm) at too high a pressure=velocity for a really good forge fire. I've used 12v Coleman InflatAlls with great results, they're intended to inflate air matresses, rubber rafts, etc. and don't develop much pressure fut do put out good volume. Most any sporting goods store will have some version to take a look at so you can keep your eyes open at Yard/garage/? sales. You ARE, I'm sure, aware scrounging, salvaging and improvisation are near musts for a blacksmith. If you can drive by a piece of iron or steel on the roadside without stopping to at least check it out you've got a ways to go to get out of the newcomer box. Frosty the Lucky. Quote Link to comment Share on other sites More sharing options...
TimB Posted October 9, 2010 Share Posted October 9, 2010 Here is what I put together from a propane bottle ( SAFETY FIRST ). I used adobe. LeeRoy I like that, that's kind of what I plan to do next, and use a vaccume motor / hair dryer, / small blower--- something that uses less electricity than the air compressor. Quote Link to comment Share on other sites More sharing options...
