March 5, 201016 yr Hello all This is my 2x72 grinder. The build is still in progress. I need to finish the tool rest, a couple of tool bars, and wiring. I am always open to suggestions. 1 2 3
March 5, 201016 yr Author Where did you get the contact wheel? I got most of my parts hereGrinder parts link
March 5, 201016 yr Where is the tracking adjustment? I've found being able to shift the belt quite useful.
March 5, 201016 yr Author Where is the tracking adjustment? I've found being able to shift the belt quite useful. The tensioner wheel also has tracking adjustment on it. you can see the bolt for that on the off side of the belt
March 30, 201016 yr Cool grinder....I do have one observation though....your grinding debris is going to get sucked right into your motor leading to early failure. Maybe you could make a shroud to protect the motor, or use a TEFC type motor (totally enclosed fan cooled).
