Anvil ID & fix up question
Hi everyone. I too have an anvil question. I bought another anvil yesterday. It's a big one, easilly over 200lb, but I havn't weighed it yet.
I was hoping that some of you could take a look at it and help me identify it. I have put up a page on my web site with a bunch of pics and dimensions. It's at: FredlyFX.com anvil page All of the pictures are clickable links to ful size pictures.
I think it is a cast steel anvil that was a factory reject. What do you guys think? If it is, should I smoth out the face and use it as is, or should I try to weld on a tool steel face? I'm leaning towards flaten and use it as is.
Any help you can offer is greatly appreciated.
As I reported over across the street, I think that this is a recent casting from Mexico as the mold line goes right through the face and horn. I don't know what alloy(s) they may be using but am interested in it's usability as they come by regularly at the local auction here in NM.
Thomas
I don't know about a factory; it just looks to me like they are from a small foundry that pours them out of what's left in the pot after their main runs---why I wonder about alloys used---may vary from run to run
As to being from Mexico the density of their appearence at fleamarkets and junk stores and auctions increases the closer you get to the border. Folks at such places are usually pretty close with their sources but I will ask as I see them---will probably be a while though.
I was wondering about some of the foundries right across from El Paso myself... BTW they are doing small swage blocks too!
Thomas
Now that you mention it Thomas, the guy did say that he has a friend in AZ who gathers most of his old blacksmithing stock and brings it with during visits. So, it is very likely this came from AZ too, which would them make it also possible that it had come up from Mexico.
I will be talking to the guy Thursday, and will ask more about the history of the anvil.
I talked with the guy I bought the anvil from and all he knows is that it came from AZ. He has a retired guy that drives around all the western states pulling a heavy trailor. My guy will buy anything blacksmithing from him to sell in his flea market/antuiqe store. Having looked at what he had available in his small new location near me, I think it may warrant a drive to his full size main location to have a look see. The same time I picked up this anvil I also got a large Pexto stake plate and a stake for $25 from him, so he has some good stuff, and is not looking for ebay prices for it.
I talked with a machinest friend on Wednesday, and we will be machining the face flat probably next weekend in exchange for me helping him build a small gantry crane over his mill so he can get larger items into it. I'll be doing the base myself with brinders and belt sanders, but he will do the face. I am hoping it will be usable once that is done, and will report back once I have it done.
I have a Peter Wright 450 lbs with badly worn edge on the back of the face. There is no edge left the first six inches from the horn, and toward the heel a large radius. I need a sharp edge on that side. What do you recommend? I understand the value of my anvil (hystorically) and don't want to ruin it.
I would reccomend getting a second anvil with good edges. If all you are looking for is a good sharp edge, then you don't need a real anvil. Check out the local scrap yard for a large solid cutoff you can set down on end. Make some type of stand to hold it upright and you will be set. If it were say 4 or 6 inches square, you could actually grind 4 different radi on it and have a nice set up for those operations that require the edge.
Or, just learn to work around what you have. Even if you were not concerned about historical value of your anvil, repairs can be iffy. Some work great, and others fail misurably. It's kind of a crap shoot.
Make a hardy tool with the edge you need---with a little planning you could make it with *4* edges of different crispnesses and just rotate as needed.
or as Fredly suggests: something like a nice chunk of 2" plate in a heavy postvise has possibilities
How about a fork lift time? They can be quite heavy, made from good steel heat treated *tough*, and will have good edges. I've scrounged several over the years for free---talk with a forklift service plcae about getting a broken one---explain what you are doing so they are not woried about you trying to re-use it on a forklift...
Thomas
