dickb Posted December 4, 2009 Share Posted December 4, 2009 I recently got a few bars of 3/4 inch square wrought iron bars. To date I have been working with mild steel. Are there any special considerations I should be aware of when forging and/or forge welding it? Thanks Quote Link to comment Share on other sites More sharing options...
John B Posted December 4, 2009 Share Posted December 4, 2009 You need it hotter Quote Link to comment Share on other sites More sharing options...
dablacksmith Posted December 4, 2009 Share Posted December 4, 2009 work it hotter than mild and watch out for it wanting to split apart or fray(like rope or wood ) depending on the quality of the wrought .. some of the stuff seems like your forge welding it back together a lot .. good luck! Quote Link to comment Share on other sites More sharing options...
Mark Emig Posted December 5, 2009 Share Posted December 5, 2009 The most important thing that I found is don't forge it below a orange heat-I always split it apart until I stopped forging it at a higher heat. Mark Quote Link to comment Share on other sites More sharing options...
Doug C Posted December 5, 2009 Share Posted December 5, 2009 Have a look here at Working Wrought Iron. Use the search function at the top of the screen. There are a fair number of threads that discuss them in various amounts.Also go to Google books and do a search. The older books on blacksmithing were likely referring to Wrought Iron. Also if you are going to split or slit then drill or punch the ends of the cut to keep the iron from splitting. Quote Link to comment Share on other sites More sharing options...
Larry H Posted December 31, 2009 Share Posted December 31, 2009 Dick you should have mentioned that to me, wrought iron is easier to work then mild steel and welds like a dream I have some in the shop, next time.... Quote Link to comment Share on other sites More sharing options...
Frank Turley Posted January 1, 2010 Share Posted January 1, 2010 I just finished three chest hinges and one lock hasp for restoring an antique Mexican, wooden chest. I was not required to use wrought iron, but I did. It makes one feel good to be true to the material and the period. I have a special stash of wrought iron beside the shop. I identified it by the spark test and by forging it to see how it behaved. I located some small strips to use that were of high quality and well refined. I wanted to avoid the gross, super stringy, least refined iron that you sometimes find, especially on wagon tires. Regarding forge welding the hinge barrels, I used a sweating heat, not a sparking heat, and it worked. Wrought iron can be welded at the brighter sparking heats, but it is not always necessary to do so. The hinge material was 1/8" x 7/8" and the hinge pin was 7/32" diameter, dead soft wire. I mention the material size to emphasize what is possible, if one is careful with the material. Wrought iron is weaker than mild steel, especially regards tensile strength. Nevertheless, it is strong enough for many applications. An example of low tensile strength is when you are cutting on the hardie. When you're down to about 1/16" or so, you can wiggle the material once or twice and it will break easily. Mild steel hangs on longer, and high carbon stell hangs on even longer. http://www.turleyforge.com Quote Link to comment Share on other sites More sharing options...
