grandpafischer Posted November 14, 2009 Share Posted November 14, 2009 Hey folks I have located an old rusty forge and was wandering if it might be worth refurbishing. It looks to be home made, what I took to be a firepot looks like a piece of 4 to 6 inch pipe ,it has a blower attatched that has a pulley on it like it had an elect motor to run it. There is some spots rusted out,and still has some cement in the bottom, but all moveable components are rusted up and wiil not move. what do ou all think? Quote Link to comment Share on other sites More sharing options...
orgtwister Posted November 14, 2009 Share Posted November 14, 2009 well its hard to say with out a picture do you have one if so it would help . Quote Link to comment Share on other sites More sharing options...
ironstein Posted November 14, 2009 Share Posted November 14, 2009 We love pictures! Post some so we know what we are looking at, then i'm sure the guys around here can advise you. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted November 14, 2009 Share Posted November 14, 2009 Depends on if you can build another one for less money, or time , than it would take to repair that one. Sometimes it is easier to start over. Quote Link to comment Share on other sites More sharing options...
David Einhorn Posted November 14, 2009 Share Posted November 14, 2009 Difficult to advise without a picture. Assuming the blower is a loss, go get an old vehicle blower at the junk yard to replace the blower, install it, do a quick patch of the holes with some chimney cement and then try using it. If that does not work for you, then post pictures. :D Quote Link to comment Share on other sites More sharing options...
grandpafischer Posted November 16, 2009 Author Share Posted November 16, 2009 THanks all I will see if I can get my son or daughter out this weekend with their digital camera and take some shots and teach me how to post, I don't have a digital camera, thanks again grandpa Quote Link to comment Share on other sites More sharing options...
arftist Posted November 17, 2009 Share Posted November 17, 2009 Meanwhile, spray any parts which should be moving with penetrating oil, to get a head start. Spray the all every day. It is almost always easier to repair a machine than to build a new one. Quote Link to comment Share on other sites More sharing options...
Pac Posted November 17, 2009 Share Posted November 17, 2009 Have some similar questions about a Buffalo forge and blower. The only info I could find was an old unreadable ebay ad that calls it an agricultural forge. Here are the questions: I haven't started cleaning it yet, but assuming the forge is cast iron will I be able to bandage the broken pan together with flux core wire? That is all I have available. The plan was to nut and bolt it back together with angle iron, weld the pan, and line it. More than likely it will be left outside hopefully covered and used maybe a few times a month. I'm not able to soak the blower in diesel where i'm located, what would be the next best thing? Can I use vinegar in a plastic tub with similar results? It does turn back and forth, but it rubs the cover and there's a bunch of crap in there. It's hard to tell, but any ideas on what the tools were for? Any help is appreciated... Thanks, Dave Quote Link to comment Share on other sites More sharing options...
Mainely,Bob Posted November 17, 2009 Share Posted November 17, 2009 Dave,I`d just try bolting or riveting the pieces of the forge together if I was planning on lining it.Welding cast is tricky and near impossible w/flux core. To clean parts I`ve used both white vinegar and pool type acid in plastic tubs or buckets to good effect.If you decide to use acid then get long gloves(acid proof) and wear a faceshield.You WILL drop something and splash,DAMHIKT. The parts will come out of the vinegar or acid black,brush/rinse the black off and then dry and IMMEDIATELY spray with oil, WD40,etc or it will be rusty again in the morning. I`ve had good luck freeing up hopelessly rusted assemblies and nuts and bolts with the vinegar.It is not as aggressive and takes longer than acid but it`s safer too. You can always Google electrolosis if you`re in a hurry and have a battery charger around. Quote Link to comment Share on other sites More sharing options...
Pac Posted November 17, 2009 Share Posted November 17, 2009 I'm in no hurry, thanks for the info Bob. Quote Link to comment Share on other sites More sharing options...
arftist Posted November 18, 2009 Share Posted November 18, 2009 Tools, left to right, Looks like a crimper, tire chain tool, lead melting pot, unknown, lead ladle. Quote Link to comment Share on other sites More sharing options...
