setting railings in granite steps
3 posts in one day... this is a record for me...
what do you guys use to anchor railings into granite steps? lead-packing like the old days, or masonry epoxy?
just curious what everyone is doing, because i have to install a set on monday.
mark
Either, epoxy is probably easier and just as good,
hm. thanks john, i'm going to read up on epoxy
I use pour rock, it's cheap, sets up fast and I haven't had a problem with it yet.
scott, are you talking about that euco rock stuff? the pourable grout?
I use either pour rock or epoxy depending on the temperature-if its below 50 I use the epoxy. Only problem is it's pricey.
MarkEmig
What is the issue with pouring lead?
Gobbler
I have no issue with either, and use what is appropriate for the specific application
Epoxy, prepare, mix 'n fix.
Lead, melting it, pouring it, packing it, damp in sockets and potential eruption if any moisture present, surroundings potential for damage around the area.
The choice is yours,
wow, a lot of great info from everyone. Mark Emig, what kind of epoxy do you use? i think we have similar climates to contend with
the railings are going right in the middle of Boston, about a mile from the water, large temp variations, blizzards, -0*F, the works.
Edited by MarkC
Mark we call it pour rock, rock tite, rock hard, its the same thing a quick setting mortar you can get at the local hardware store nothing special.
the quick setting mortar was the final outcome, after lengthly conversations with the builder.
thanks again everyone.
mark
The issue with lead is simple-lead exposure ( and the aforementioned pouring problems). From the research I have done into lead exposure (I worked in garages for years and handled a LOT of lead wheel weights) is that whenever you handle lead, lead rubs of onto your skin in microscopic dust form which can easily be breathed in if you happen to rub your face etc. I have symptoms of lead overexposure in the form of short term memory problems and other aggravating things. Very annoying to deal with. I suggest that you all try to avoid it if you can.
Mark Emig
