K. Bryan Morgan Posted September 26, 2009 Share Posted September 26, 2009 Finally got it done. Been busy getting the house ready for winter. Priorities you know. Made from a break drum, 1/8" floor plate and 20 gauge 2 x 4 studs. Very sturdy and easy to break down for transport or moving. 2' x 2' hearth. I'm using a hair dryer for air blast. I went to hook it up and get a fire going and work on somethings and as soon as I turned on the hair dryer. I got the dreaded blue smoke. Dead hair dryer. Oh well. Quote Link to comment Share on other sites More sharing options...
Dave Parker Posted September 27, 2009 Share Posted September 27, 2009 Nice design Bryan, I was looking at using a tool cart for mine. I saw one in Harbor Freight about the right size and it already has wheels. The top will need reinforced. I have to have a mobile forge. The blower is almost finished; the firepot is my next project. A pre-built cart will cut down my work time. I probably should have started with the firepot and hearth but a blower fell into my hands and with my limited free time, I’m doing this a little at a time. Quote Link to comment Share on other sites More sharing options...
Frosty Posted September 27, 2009 Share Posted September 27, 2009 Looks good Bryan. Don't let the smoke out next time, electrical things run on smoke and if you let it out they won't work anymore. Frosty Quote Link to comment Share on other sites More sharing options...
Avadon Posted September 27, 2009 Share Posted September 27, 2009 Looks real solid, you should be able to get some high heat out of that. You might want to attach some large wheels and handles for ease of portability unless you have it one spot all the time. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted September 27, 2009 Share Posted September 27, 2009 Nice set up. I'll have to keep that in mind for later. Those studs are rather economical and a good idea. Phil Quote Link to comment Share on other sites More sharing options...
K. Bryan Morgan Posted September 27, 2009 Author Share Posted September 27, 2009 Frosty, Yes the dreaded blue smoke. Gotta keep that little monster bottled up for sure. Avadon, I thought of that too. But for me its real easy to move as is. I also like the height it is and if i added wheels it would raise it some. Or, I would need to cut off some leg. I will do that on the next one. Thank you pkrankow. Quote Link to comment Share on other sites More sharing options...
Rob Browne Posted September 27, 2009 Share Posted September 27, 2009 Nice design and well done. You should get lots of use out of it. Definitely takes the simple brake drum forge to another level. Enjoy Quote Link to comment Share on other sites More sharing options...
K. Bryan Morgan Posted September 28, 2009 Author Share Posted September 28, 2009 Thanks rmcpb, I don't know about another level, but it is simple to do without welding skills, equipment ect. Question. Since its galvanized, would it get hot enough on the edges to be a danger? Quote Link to comment Share on other sites More sharing options...
Rob Browne Posted September 28, 2009 Share Posted September 28, 2009 I take it that the checkerplate is black steel and its the frame thats galvanised. If so you will be alright as the frame will never get hot enough to cause problems. Quote Link to comment Share on other sites More sharing options...
K. Bryan Morgan Posted September 28, 2009 Author Share Posted September 28, 2009 Yes that's right, it's called floor plate. It's mild steel, nothing on the surface. Quote Link to comment Share on other sites More sharing options...
Rob Browne Posted September 28, 2009 Share Posted September 28, 2009 Now fire it up and give it a go!! Oh, and don't forget to report back on how you go. Enjoy :) Quote Link to comment Share on other sites More sharing options...
