coil spring
Get a piece of pipe a little smaller than the spring. Heat the spring up, I usualy get about 2 wraps hot, put the whole spring on the pipe, and pull the end to straighten. Basically using heat and "unwind" the spring, opposite of how it was made.
Good luck,
Cliff
