johnptc Posted May 30, 2009 Share Posted May 30, 2009 just finished installing this memorial piece this morning with my better half the artist built from 0.25 inch bronze plate. 7 feet diameter x 2 feet wide Quote Link to comment Share on other sites More sharing options...
markb Posted May 30, 2009 Share Posted May 30, 2009 What kind of finish? Bare metal ,patina with age? I assume it's in a park? Able to touch and feel. I love the simple shape although i doubt it was easy to create, a beautiful piece. Please tell us more about it. Mark Quote Link to comment Share on other sites More sharing options...
johnptc Posted May 30, 2009 Author Share Posted May 30, 2009 its at a school and designed to be kid friendly...lying sitting etc. it is in memory of one of the founders. its fabricated from flat plate..........mig welded with argon and bronze wire...ground and re welded until it looked good. the finish is bare metal sanded....will patina in time. dedication will be june 12th Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 31, 2009 Share Posted May 31, 2009 Very nice sculpture, I like the simplicity and availability. Is it in LA? Frosty Quote Link to comment Share on other sites More sharing options...
johnptc Posted May 31, 2009 Author Share Posted May 31, 2009 Very nice sculpture, I like the simplicity and availability. Is it in LA? Frosty Yes sir in LA...... the dedication isnt until june13... if i sounded cryptic.......its now in a tarp until then. thanks for looking :) Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 1, 2009 Share Posted June 1, 2009 Cool. Once in a great while we get back to LA and next time it'll be cool to have stuff to look at I can brag about knowing the artist. Thanks for showing us. We LOVE pictures. Frosty Quote Link to comment Share on other sites More sharing options...
Fe-Wood Posted June 1, 2009 Share Posted June 1, 2009 Nice work!! you should be proud! Quote Link to comment Share on other sites More sharing options...
Mike Ameling Posted June 1, 2009 Share Posted June 1, 2009 I assume some type of cement base set down in the ground. How did you attach the ring to the base? Through bolts? Flanges attached on the sides? I learned a long time ago to NEVER underestimate the power of a dozen "motivated" kids - even with a 1 ton boulder setting on/in the ground! I kind of shudder to think what they might have been able to do with a few ... tools! And it wasn't even malicious vandalism - just a spur-of-the-moment thought. Mikey - that grumpy ol' German blacksmith out in the Hinterlands Quote Link to comment Share on other sites More sharing options...
johnptc Posted June 1, 2009 Author Share Posted June 1, 2009 I assume some type of cement base set down in the ground. How did you attach the ring to the base? Through bolts? Flanges attached on the sides? I learned a long time ago to NEVER underestimate the power of a dozen "motivated" kids - even with a 1 ton boulder setting on/in the ground! I kind of shudder to think what they might have been able to do with a few ... tools! And it wasn't even malicious vandalism - just a spur-of-the-moment thought. Mikey - that grumpy ol' German blacksmith out in the Hinterlands thanks for the question !! we poured a reinforced block of concrete 36x36x36 with four hollow vertical tubes. the sculpture has four 1.5 inch tubes in the bottom going up to the inner ring with internal supports. once on site i welded four steel bars into the the tubes in the sculpture. the tubes in the concrete based were then filled with cement-all ( 9000psi dry pack) and the piece lowered down......... the enginner i talked with said the biggest load could be seismic but kids could rival it :( Quote Link to comment Share on other sites More sharing options...
Double Y Posted June 3, 2009 Share Posted June 3, 2009 Very Nice! Quote Link to comment Share on other sites More sharing options...
