elija6266
    5
Profile Information
  • Gender
    Male
  • Location
    USA
  • Interests
    Reading
Recent Profile Visitors
662 profile views
  1. Hello there, I am new to the world of blacksmithing and am excited to start my journey into this craft. After doing some initial research; I realized there's a lot to learn and a myriad of tools and techniques to consider. I am hoping to get some advice from experienced blacksmiths here on the forum. To give you a bit of background; I have always been fascinated by the artistry and skill involved in blacksmithing. I have watched numerous videos and read a few introductory books; but I know that nothing beats practical experience and advice from seasoned professionals. I understand that a good hammer and anvil are fundamental; but what other tools should I consider investing in as a beginner? Are there any specific brands or types that you would recommend for someone just starting out? I have a small garage where I plan to set up my forge. What are some must-have considerations for creating a safe and efficient workspace? Any tips on ventilation; layout; or necessary safety equipment would be greatly appreciated. I would love to start with some simple projects to build my skills. What are some good beginner projects that are both manageable and instructive? If you have any tutorials or resources; please share them. Also I have gone through this post: https://www.iforgeiron.com/topic/50546-projects-and-materials-ccsp-for-a-beginner/ which definitely helped me out a lot. Besides this forum; are there any other resources like books; online courses; or local workshops that you would recommend for a novice blacksmith? I am sure there are common pitfalls that new blacksmiths encounter. What are some mistakes you made or seen others make that I should be aware of and try to avoid? Thank you all in advance for your time and guidance.
  2. hello there I do not have any personal experience; but I heard about it Some welders use it to prevent MIG spatter; I think in hairspray, chemicals are usually used to prevent the spatter. You can try it if you get the best result, that is good for you |If you are not successful, then you just leave it. because I think it depends on the weather.
  3. I agree with you. I also like the article information on how they managed to innovate and keep the shop operational under difficult conditions. I do not have any personal experience transferring the chain from ship to ship. I think what happened with the with the tools of Building 105 discussions on IFI is so exciting to see what will happen with these tools.
  4. Soft steel is good for workability. This type of steel makes machines and gives the metal.
  5. Make sure the area of the bar you are working on is heated equally overall. then consider the angle and force of your hammer hits when forging. make sure the anvil's bar is set up correctly. reduce the corners by a small amount. Turn the handle 90 degrees. Control continues with support of this slow decline. It is fine to use position tongs, but make sure you are not too much hold the bar. A twist is beginning to take shape stop and smooth it out. Practice makes perfect when it comes to shaping.
