I'll be glad to.
Mule
There are no pictures but I think this is the complete text. Pictures of the various tools can probably be found with a google search, or a similar search.
An Introduction to blacksmiths tools
Started by John B, Oct 17 2010 05:54 AM
Page 1 of 2
1
2
Next
Reply to this topic
21 replies to this topic
#1 [An Introduction to blacksmiths tools: post #1] John B
Senior Member
LocationDawlish, Devon, UK
Posted 17 October 2010 - 05:54 AM
Many newcomers to blacksmithing have little knowledge of the blacksmiths basic tools, what they are called, and when they are used.
This list, originally courtesy of Glendale Forge http://www.glendaleforge.co.uk may help. Thanks also to Frank Turley, and others for contributing the American Terminology and descriptions to allow cross referencing
I have added some other terms also in common use that were originally missed off the list.
The pictures illustrated are mostly of the tools I had in my workshop, some are home made, some bought and others inherited, but all should help to give a visual identification for you to hopefully understand and relate to what may be being discussed.
Blacksmiths' Tools Explained
The Blacksmith's Tools have changed little if at all in design over the centuries and an attempt is made here to explain briefly some of those in more common use today.
I hope you find this useful when looking for, talking about, or using new tools
Anvil: Something solid to forge metal on. A London pattern anvil with a single bick (or horn or beak) is usually all that is required and should be used on a stand so that the top is level with the clenched fist. Ideal weight of anvil 3 cwt. Other substitutes and types can also be found and utilised.
Ball Tools: Top and bottom tools used for forming ROUND or SQUAT BALLS or knobs on shanks or otherwise as required
Squat Ball Swages another application.JPG Squat Ball Swages and smaller sample.JPG Ball Tool swages.JPG
Bending Forks: See also Horns and Scrolling Wrenches can be used in Hardie holes, vises, or as wrenches Is in effect a pair of horns on a handle, so that in conjunction with another such wrench or anvil horns one can adjust the shape of scrolls or make light bends. They can also be utilised for making specific bends/items Hickey is an old US term for Scroll Wrench From Frank Turley.
Bending fork selection aka Scroll wrech.jpg Bending forks for jig for curtain rings.jpg
Bolster or Punch Plate; A plate used to support material when it is being punched or drifted, (or it could be a swage block) with different size holes, round and square, and slots in to accommodate your punches and drifts.
Bosh, Slack Tub, or Slack Water: A water tank attached to the front of the hearth for quenching hot metal. (Slack tub or slack water; From Frank Turley)
Bow pliers; also called Collaring tongs are used solely for the opening, closing and fitting of collars to a pair or cluster of bars to act as a permanent fastening
Breeze: Forge fuel, can be coke or coal, usually quite small pieces.
Brush (heavy wire): It is absolutely essential to remove scale and slag from a hot bar prior to commencing forging to prevent it being splashed into eyes or over bare arms. It is best to use a brush made with coarse long wire, fitted to a handle perhaps 14" long.
Butcher: A cutting tool, particularly for quickly roughing a shoulder. The one illustrated nicks all around the edges of a square bar, giving a guide ready to use the SIDE SET for setting down a tenon shoulder on the Heel bar, then a SET HAMMER is used to square up the tenon shoulders
Centre punch; For the accurate marking prior to drilling or forging.
Curved Butchers; can be used to make cut out sections and holes in plates, often used for making decorative back plates and hinges Butchers can be handled, rodded, or hand held.
CheeseFuller; A fuller made with a face resembling a wedge of cheese, enabling one to gently neck in, or reduce the thickness of a bar.
Cold chisel: For marking out and cutting steel cold, if used on hot steel they will need re heat treating. The radius on the cutting edge enables location and the ability to cut curves.
Cold Set / Cold cut: A cutting tool for nicking bars cold prior to their being broken or cut. The cutting edge is radiused, and the body is wider/thicker than the HOT SET See comparison picture (In US called Cold cut if hafted. From Frank Turley)
Cold set blade.JPG Cold set cutting edge.JPG Cold set and hot set comparison.JPG
Collaring Tongs; or Bow pliers, are used solely for the opening, closing and fitting of collars to a pair or cluster of bars to act as a permanent fastening.
Cone or Mandrel; Used to set and correct rings after they have been formed, and they come in various sizes. Some fit in the hardie hole, others in a vise, or floor standing.
Creasng Iron or Creaser (From Frank Turley): A specific type of Fuller, Used for putting in shaped grooves in horseshoes where the nails fit.
Domer; US term (see Rivet snap) From Frank Turley
Drifts; Are used to open up punched holes, or to form a taper, or a finished size
Barrel drift; Used to widen punched holes to a finished size, they can be knocked through due to the
taper on both ends
Taper or Carrot drift; Used to widen punched holes, leaving a taper in the hole useful for handled tools.
Flatter; as its name suggests, is employed in making the surface texture of the iron work piece flat or free from blemishes left by the hand hammer. Can be hand held, Handled, or Rod/Wire handled, the wire handle allows for better seating onto the workpiece, supporting the flatter loosely and not transmitting shockwaves as a rigid handle can do.
Fullers, Fullering Irons or Creasing Irons or Creasers; having radiused blades, are used for necking in or swiftly drawing down a bar. Can also be individual, Having a profiled finish to put in shaped grooves ie as in horseshoes, centre lines on blades to lighten and strengthen them, or edging features.
If half round, fullers are asked for by their diameter in inches, Fullers are not always half round, they can take various shapes, For example a British Farrier may use a Fuller, or Fullering iron to put the nail grooves in a horseshoe, In the US, the tool is often called a Creaser or Creasing Iron for putting in the "Nail Crease" in the shoe. Sometimes we put it in lengthwise or crosswise sharp bottomed fuller marks for design elements, borders etc. From Frank Turley
Hack; (US term) see Side Set From Frank Turley
Halfpenny Snub End Tool: For rounding up a Halfpenny Snub end, unfortunately only useful for a specific size.
Hammer: For general work a ball pein hammer of 11/2-2 lbs is advisable. An identical spare should always be kept handy in case of emergency.
Hand Square: A Blacksmith's square for use with hot metals.
Hardie: Fits in the square or 'hardie' hole in the anvil and is used for cutting hot iron at the anvil.
Hearth: Sometimes referred to as Forge; fired on coke beans, coal or other fuels. Forced draught from a fan or blower, produces intense forging and welding temperatures quickly. No real substitute for this original equipment.
Hickey (US): is an old term for Scroll Wrench From Frank Turley.
Horns: Either fitting in the vice or in the hardie hole, allow the bending or adjusting of, in particular, scrolls and similarly shaped bars
Hot Set or Hot Cut; A finer edged tool than the cold set, and used for cutting off hot metal, again hand held, handled or rodded
Hump tools; (US contributed re tazmig33 iForge site) are radius blocks that support the workpiece (hammer or tool) when drifting. In some cases the front of your tool is at a different height than the striking side so there are many different height hump tools, used like a bolster or punch plate. see Brian Brazeal's demo on hammer making
Leg Vise: A Blacksmith's Vise designed to withstand general abuse, heavy bending and sledge-hammering. The shock is taken on its leg set into the floor. This is not a precision instrument and should not be likened to an Engineer's Vise.
Mandrel or Cone; Used to set and correct rings after they have been formed, and they come in various sizes. Some fit in the hardie hole, others in a vise, or floor standing.
Monkey Tool: Used for shouldering up a swaged tenon, the elongated sight hole being simply to ensure that the tenon does not foul inside the Monkey.
Punches; Round punch Used to make round holes in hot metal, Square punch Used to make square holes in hot metal,
These can be hand held, handled, or rodded.(wire handled)
Rivet set and snap; Can be one combined or two separate tools used to Set up the rivet, (close all the pieces together prior to riveting) and the Snap used to finish the dome head of the rivet, it can also be used to support a domed head when riveting to secure the pieces together. (Domer is a US term From Frank Turley)
Rope Tools: Mould or swage iron in such a fashion that when twisted the bar will resemble a length of rope. Limited range of uses
Set Hammer: Not a hammer as such, but is a tool used struck by a sledge to produce a very definite square shoulder on a stepped forging such as a tenon on a heel. To drive the set hammer well into the corner, the best results are gained by directing the blow diagonally, hitting the corner of the head.
Scrolling Tongs or Round nose pliers; are used chiefly in making Scrolls, holding the bar on to the Scroll Tool and subsequently adjusting the tip of the scroll.
Scroll Tool or Scroll Jig: A former or shaper on which to reproduce a number of identical scroll motifs. Note the ends are elevated to allow starting the scroll before pulling it around the rest of the form using scroll wrenches or scrolling tongs to control the curving. You will also see one that is less tighter than the others, this is for snub end scrolls that will not fit into the tighter rolled scrolling tools.
Scroll Wrench or Bending Forks: Is in effect a pair of horns on a handle, so that in conjunction with another such wrench or anvil horns one can adjust the shape of scrolls or make light bends. Hickey is an old US term for Scroll Wrench From Frank Turley.
Side Set, Hack (US): Used for squaring up a shoulder prior to using the set hammer. (Hack From Frank Turley)
Slack Tub see also Bosh; A water tank attached to the front of the hearth for quenching hot metal. (Slack tub or slack water; From Frank Turley)
Slide Valve; Used to control the air flow into the forge, and is fitted between the blower/fan and the tuyere or tue iron. The one illustrated is fitted to the ash dump for a bottom blast forge, and the tue has not yet been fitted
Spring Tool or Veining Tool: A tool designed as a multi-purpose press invaluable for ribbing, veining and raising Acanthus leaves, making obsolete a whole range of Stakes. Not only making leaves more quickly and accurately, but also is used for decorating sheet and making rosettes etc. Can also be a top and bottom tool linked by a loop of steel 'spring' to keep tools aligned when in use.
Swage, (swedge sometimes, rhyming with sledge). From Frank Turley: Top and bottom tools for forging a round section. You can also have square swages. Handled, rodded or hand held top tools, the lower part fits in the hardie hole and can be used seperately, for instance when forging half round sections for ball collars, or backing for when forge welding bundles together to help keep the strands in close proximity making it easier to fuse them together. Specified by diameter produced in inches
Swages can also take other shapes than a near-half round. Again, in farriery, we sometimes swage light horseshoe stock by driving it into a bottom swage that has a sort of double-vee indent side by side. This leaves a raised carrot shape almost at the centre. When the stock is drawn through and turned over, you get the reverse image, a nail groove a little eccentric from centre. I have often used a bottom "shallow swage" (home made) for giving a Suffolk latch handle a nice appearance. (From Frank Turley)
Swage Block: Rectangular block of Iron with a variety of shapes around its periphery for swaging on. Also has various shapes of holes through its face which act as bolsters. Must be used on a stand.
Tongs; are used for holding hot pieces of metal and are made in a variety of sizes and strengths strictly according to the size and shape of bar the Blacksmith intends to hold. It is of paramount importance that the correct size of tong is used in each particular application or the bar may well jump out of the tong and an accident occur. The use of one tong for a variety of jobs is therefore inviting trouble.
Tuyere or Tue Iron; In the hearth where the air input meets the fuel it can be plain hole(s) in a plate, or in a water cooled jacket.
Twisting Wrench: Simply a device for imparting torque to a bar to give it the twisted effect, second only to the scroll in its importance as a decorative design.
Veining Tool (See Spring Tool)
As you can see, many of these traditional tools need a striker to assist the 'smith to be used correctly, hence the development of the new alternatives which do the same tasks as the traditional tools, but can be operated by one person, many only needing a simple adaptation, others being newer tools like the Blacksmiths helper or Smithin' Magician and guillotine tools etc.
That's progress and innovation, and that is what the craft is all about.
That is what I have,
Mule
