757 -
Everything posted by thingmaker3
I'm going to go out on a limb here and respectfully disagree. I concur the wrist, elbow and shoulder should be roughly co-planer. I concur one should not lift one's shoulder when hammering. More than just one muscle group should, however, be used for forging. I'm not saying there was no bad form or no over-exertion. I am saying good form uses the whole body, the right grip on the tool, and the right tool. I hope your healing goes well enough to impress your physician. I hope you do not have further injury.
A hand-hammer only has so much kinetic energy that I can put into it. I want as little as possible of that kinetic energy converted to sound or "absorbed" by sand or wood or such. I want as much as possible into that glowing hunk o' metal! The more the anvil or stand move, the more of my hammer's kinetic energy goes to waste. And that energy comes 100% from MY muscles, doggonnit!
Drawings and Blueprints, what are they worth?
thingmaker3 replied to Jason M's topic in Blacksmithing, General Discussion
This person: http://www.iforgeiron.com/user/7946-jason-m/ I'm betting it's an honest inquiry by someone wanting to learn. -
The monetary value of a drawing or blueprint depends on what it is, who made it, how easy it is to read, how accurate it is, how complete it is, and whether I want it. :P -
Feh. REAL manliness is using one's BARE FIST to pound the glowing iron! I witnessed a similar demo at the 2006 ABANA conference in Seattle. It is impressive see the metal moving under a jackhammer, as well as to see the smith manipulating the jackhammer about the work. And those Finlanders do nice work indeed!
Worth its weight in gold
thingmaker3 replied to K. Bryan Morgan's topic in Blacksmithing, General Discussion
I think a lot of these folk are holding out for some of P.T. Barnum's one-born-every-minute types. I think other of these folk are said types themselves. -
Knife-making can get the hands permanantly dirty. If you plan to be a surgeon, grubbing around inside human bodies, you might start wearing gloves when knife-making. Of course there are more specialties in medicine than I can even guess at. For steel, there are plenty of good tools thrown away every day. Check local cabinet shops for larger cast-off saw blades or planar blades. Check auto shops for dead leaf springs. Find someone who makes custom fishing rods - they throw away perfectly good A-2 steel big enough to make small knives. Don't ignore the steels you can't heat-treat yourself. Shipping blades off for heat treat can be quite affordable. And please DO post pictures if you use a 420J scalpel you made! :)
Heat treating 1080 / 1084 / C80W2 steel
thingmaker3 replied to 30cal_Fun's topic in Heat Treating Knives, Blades etc
780C would be hot enough only if the steel were heated very very slowly. It is important to remember the phase diagram is isothermal. If we heat more quickly, the transformtion temperature increases. Eutectioid transformation temperature can be around 1600F when induction heating small sections. I echo Son_Of_Bluegrass' suggestion. You might get away with as little as 800C. -
How 'bout a cool grand for an old rusty rivet forge? http://portland.craigslist.org/clc/grd/1884237208.html Fellow says "You will not likely see another this old very often." I see them about twice per month on the local Craigslist, so I guess twice a month is not very often. :lol: -
Adding Carbon to Steel without Melting it?
thingmaker3 replied to Robert Simmons's topic in Metallurgy
The full equation requires at least four axis, Mr. P. We have to account for initial carbon concentrations, and the presence of things like nickel or silicon. What I had in mind was something like I have in a couple of my books: set of graphs showing carbon content x millimeters below surface after y hours at z heat for a specific steel of uniform size. I can dig out some titles later in the week if you wish... might find them in your local university library... -
I suggest you do the math again, making sure to compare dwellings of similar square foot size. You might also look into renting a duplex..
Rate of carbon diffusion in steel is proportional to the square of the Kelvin temperature. Translation: pack carburization would take days & days at dull heats, hours & hours at medium heats, and a few hours at brighter heats. Note also: the "case" is not just a well-defined layer where the carbon content drops off at the edge like some underwater cliff. There is a gradient. Try an internet search on "Ficke's Second Law of Diffusion." Don't get bogged down in the math examples, but do study the graphs. -
Some observations about twist method for making tongs
thingmaker3 replied to evfreek's topic in Tools, general discussion
Thank you, John. That makes a whole lot more sense. -
I define mass the same as they taught in high-school: height x width x lenght x density. But why do I need longer reigns for a larger diameter piece? I could understand more stout reigns for a heavier piece. For example, if I'm handling a 2" diameter by 5" long pipe versus a 3/4" diameter 5" bar, why do I need beefier tongs for the tube? Why can I get away with 15" reigns holding a knife blank flat, but have to switch to 22" when dressing the profile? How come the overall mass of the workpiece has less influence on the size of tong than a single dimension of said workpiece's cross-section? Am I thinking about this backward? -
Chemical composition of A36 depends on thickness. Carbon ranges from 25 points if less than 20mm to 29 points for 100mm or thicker. Manganese is not specified for stock of less than 20mm, and can be between 0.8% and 1.2% for stock thicker than 20mm. Some manufacturers put in a bit of copper. But, yes, it can indeed be forge-welded.
Heck, I'd be happy to find a commercial mix that doesn't crumble! I cope by sprinkling fine sand in the cracks prior to lighting. It fuses in and eventually the cracking slows down.
I've seen that Machinery's chart (or variants thereof) a few times. What I don't understand is why the chart goes by diameter or side length of the stock instead of by mass of the stock. Can someone explain the theory at work here? -
bandsaw converted into belt sander?
thingmaker3 replied to ironstein's topic in Grinders, Sanders, etc
A lot of industrial supply houses and woodworking suplly stores sell 1/2" belts in different lengths and grits. -
For plain-carbon and low-alloy hypoeutectoid steels (stuff like 1060 or 4140), the transition temperature is about 50F above the Curie point. For hypereutectoid steels and high alloy steels (like 1095, or CPM9V), all bets are off.
What a marvelous oppertunity! I hope you skewered that thing & fried it up with some hush-puppies and slaw!!
Adam, remember that Harcourt was writing about the bursting of wrought iron, not mild steel. Wrought iron has up to a quarter million ferrous silicate stringers per square inch of cross section. Mild steel does not. Many of the books from the late 19th and early 20th centuries deal with proper technique to avoid similar phenomenon in wroght iron. You-tube videos deal primarily with our modern homogenous steels.
What Kind of Steel for Serving Utensils
thingmaker3 replied to ofafeather's topic in Blacksmithing, General Discussion
Clean it really good & soak it in citric acid. -
Since these steels are being hyped as good for grouser parts, they might make really good picks or shovels or grub hoes.
Hey Sam! Thanks for starting this thread. All these interesting replies have talked me into getting some more of these spiffy locking pliers! After browsing through some of the locking plier patents at the USPTO website, I might even try to make some of my own. Never could've happened without ye, Sam! :lol:
