Frosty Posted November 28, 2016 Share Posted November 28, 2016 4 hours ago, Latticino said: Suggest a hinged counterweighted ash dump instead of a pipe cap. Depending on what you are burning, that will make your life a lot easier IMHO. Oh man I forgot the pipe cap ash dump and I'm usually right on that one. I think the beautiful job distracted me. What do you think Latticino, am I losing it or was it just a slip? I like clamp on semi exhaust flap caps, you've seen them on semi exhaust stacks. Upside down on the bottom of the tuyere, the counter weight keeps them closed and a flip with something opens them to dump the ash. If you get coal gas in the tuyere and it pops it just opens the flap, dumps the ash and closes up. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Christopher Lawrence Posted December 30, 2016 Author Share Posted December 30, 2016 Well it has been some time since my last post. Weather, School, Darkness and car accident has put a damper on the build time. That being said I am nearly done. All that I have left to do is the air handling to be up and running. I added the extra plate because I thought the cart was a bit to thin. I added the ring to make the fire pot / coke handling area a bit bigger. I want to say thank you for all your input and guidance. The finished product is a lot different then what I had originally intended, that was because I was making a lot of rookie mistakes. Thank you all again for helping me so that I was not rebuilding over and over. Quote Link to comment Share on other sites More sharing options...
arkie Posted December 31, 2016 Share Posted December 31, 2016 Nice job. Most folks leave room under the ash dump for a bucket to catch the ash & clinker. Quote Link to comment Share on other sites More sharing options...
Christopher Lawrence Posted December 31, 2016 Author Share Posted December 31, 2016 Yes, I bought the pipe before I bought the cart. That is okay I have an old cast iron frying pan that I can use Quote Link to comment Share on other sites More sharing options...
Dale Russell Posted December 31, 2016 Share Posted December 31, 2016 Christopher , simple fix , unscrew bottom section of pipe , cut it shorter , then replace it BTW , nice looking forge , should serve you well Dale Russell Quote Link to comment Share on other sites More sharing options...
Frosty Posted January 1, 2017 Share Posted January 1, 2017 It looks really good Christopher. The ash trap can be shorter but it's not a must. A frying pa or just sweeping the ash up off that nice shelf would work nicely. The important thing is to NOT let hot coals fall in the leaves or dry . . . stuff under the forge. I'll be watching for pics of it with a fire and stock in it. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Tubalcain2 Posted January 1, 2017 Share Posted January 1, 2017 nice job. that's a forge to be proud of. better than most homemade ones i've seen. Quote Link to comment Share on other sites More sharing options...
Christopher Lawrence Posted January 1, 2017 Author Share Posted January 1, 2017 Okay finally fire! We only had a couple of hours to work so all we did was a little tapering of a RR spike but for a first firing so far so good Quote Link to comment Share on other sites More sharing options...
B_HOSS Posted January 9, 2017 Share Posted January 9, 2017 nicely done. Quote Link to comment Share on other sites More sharing options...
