Sign in to follow this
Followers 0
Phil Patrick
Arbor Press
6 posts in this topic
Quick question.
Has anyone here successfully used an arbor press in the blacksmithing world for fullering, flattening, etc? I realize you couldn't use a wimpy little China freight one, but one with some uummf.
Any thoughts would be as usual welcome.
Phil
Share this post
Link to post
I know several people who use a decent sized arbor press for putting maker's marks on pieces, but I dont know anyone who uses them for any sort of forging, for that you'd probably want a screw/ fly press.
Share this post
Link to post
Its kinda slow and clunky seems that I always need some one else to help holdin an pullin.
But with the correct tools it may work if you only want 1 squish at a time.
Share this post
Link to post
I've got a good sized arbor press, but I've never used it for anything in blacksmithing yet. I got it for free and it just sets on the end of the bench in my other shop (not in the blacksmith shop). The only thing I've used it for was as a Kydex press when I made a couple of sheaths.
Steve
Share this post
Link to post
I have a friend that forges professionally. He originally got an arbor press when he was starting out, to see if he could fuller or butcher hot steel. He doesn't use it for forging now, so I'm guessing it didn't work too well.
Share this post
Link to post
if im thinking about the same thing as you ..... you wont get the 'return of energy' that you get from a fly press, its essentially a vertical rack and pinion, ive got one gathering dust somewhere, and thats all it does (except broaching the occasional keyway)
On a flypress you can 'bump' which allows you to draw-out / strike multiple blows without to much (excessive) input on the handle, they give you a little bit of your input back for 'free' on the ram return 'up' stroke.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Followers 0
