August 10, 201213 yr Hi, This is my go on the scrolling wrench described by Mark Aspery in his first book. An interesting an rewarding exercise really. Only difference is that I used spring steel and made them slightly more light weight. Wrench size 1/2" and 3/4" (12mm and 20mm).
August 10, 201213 yr Very well done, they should last a lifetime. I'd radius those inside corners a bit..... :)
August 10, 201213 yr Very well done, they should last a lifetime. I'd radius those inside corners a bit..... :) second that....
November 7, 201213 yr Very well done, they should last a lifetime. I'd radius those inside corners a bit..... :) Bob S second that.... and a third for the radius cuts , they will not shear of when working with them . Sam
November 7, 201213 yr Author Tubbe that is gorgeous work! Thank you Sam, and all! It was a good project, and I will most likely do some more of these in different sizes...
November 7, 201213 yr Good looking scrolling wrenches, good solid workmanship. Well done. A little radius on the inside corners will let them work perfectly for your great grandchildren. Dog wrenches? I kind of expected to see dog's heads or similar as finial decorations or read an explanation about using them on something dog related. Again, well done. Frosty The Lucky.
