February 7, 200917 yr What is the difference between a heading plate & a bolster I have used the terms interchangeably throughout my career as a smith. I think that -'Wind direction during use'- is probably the single most important factor determining the use of one name over another that I have seen. Does anyone have a definitive definition?
February 7, 200917 yr I'm no expert, but my guess is that the bolster, based on definition, is to support or hold, and the header, while also being useful for this, is a tool specific to it's name.
February 7, 200917 yr Mark, I'm only guessing and I know I'll be corrected. A bolster plate is inclusive; it can be used for heading material and shaping material along it's length. A heading plate exclusively addresses the end, the head, of the stock.
February 7, 200917 yr FWIW, this is my personal definition: A bolster is any sort of support under work. In the blacksmithing world, it could be a piece of material bent into a "U" which is put under hot work to support a drifting operation. OTOH, a heading tool has a defined internal dimension (but not required to be round) to support a specific heading operation.
February 7, 200917 yr Mark...I would make a post, but if you don't know, we ain't gonna and that's for sure
February 7, 200917 yr Author I agree with the opinions stated. I think Nett's is closest to my own opinion. But it's just that, an opinion. I was really looking for chapter and verse. Even in older text I cannot find a definition. A heading plate to me was/is a flat surface with a hole in it. A bolster is anything other than a flat surface with a hole in it. In the photos attached I am drifting over two different plates. In fact one was used to make the other (as shown in photo). I know what I WANT to call each piece, but I cannot find anything that offers a definition. Edited February 7, 200917 yr by Mark Aspery Spullin
February 7, 200917 yr Well I will put in my two cents. In a power press, mechanical or hydraulic, a bolster is the upper and lower plate that the die shoes bolt to. I don't know if this has any bearing on the discussion.
February 7, 200917 yr I believe this restates Hollis's definition. Header; One who, or that which, heads nails, rivets, etc., esp. a machine for heading. Bolster; To support, hold up, or maintain with difficulty or unusual effort; -- often with up. A Header is a special case of bolster - supporting the heading operation. In this case it is the use of the support that defines the tool. Mark, both of your supports are bolsters as they are shown in use. grant
February 7, 200917 yr I would use a bolster for suporting whilst punching and a header to head bolts and rivets the header is a lot smaller than the bolster as you need to angle the blows to form the head ,if you used the wide flat plate of a bolster desined to suport the punched piece you could not form a good shape of head.
February 7, 200917 yr Author . I would still be inclined to follow the lead of Mr. Lillico and call them bolster and swage bolster Of course, I could be wrong, flipping through some books and quoting them doesn't make one right :-) Thanks Gerald, I've followed Lillico for a long time now - I see no reason to abandon his council at this stage! Good research - thank you. Can you give me chapter and verse (page and paragraph) please. Thanks to all who have contributed.
February 7, 200917 yr In my experience in industrial Blacksmithing a Bolster was used to support material in some matter, such as bolster blocks in a power hammer which supported and anchored the various hammer dies, or in the use of a 'Header' machine. In the header machine the bolster clamped the material in place and a 'Header" struck the protruding end of the bar and formed the head shape. This is the same type of machine used to form button head rivits or hex head bolts etc. Terry
