Phil Patrick Posted February 3, 2009 Share Posted February 3, 2009 I am feeling pretty lucky today so I have to brag. I have just secured a rather large supply of the BIG torsion garage door springs. The material is about 3/8th in diameter, coil diameter of 6" (ish), 1 foot long. The father of a good friend of mine does garage door work and has a boatload of the things. Now all I have to do is figure out what to use them for! You all now may bow at my feet and turn green with jealousy. Quote Link to comment Share on other sites More sharing options...
Dodge Posted February 3, 2009 Share Posted February 3, 2009 COOL!!. I got some of that too, from where I use to work. Makes nice small folder sized blades as well as a kajillion other small tool ideas. Wished I would have salvaged more!! :D Quote Link to comment Share on other sites More sharing options...
tech413 Posted February 3, 2009 Share Posted February 3, 2009 Nice!!! I'm trying to talk to the people that take care of our doors at work to get some. Congrats!! Quote Link to comment Share on other sites More sharing options...
MetalMuncher Posted February 3, 2009 Share Posted February 3, 2009 Score indeed, good job! Quote Link to comment Share on other sites More sharing options...
keykeeper Posted February 3, 2009 Share Posted February 3, 2009 I have literally a half ton of various stock sizes of the springs from roll up doors, provided by my blacksmith friendly neighbor. He comes over and watches me work sometimes. He started bringing home the stuff that would otherwise be thrown out for the junk man-Springs, shafts, motors, gear reduction heads, long chains similar to bicycle chains, hollow tube, angle iron, whew, I'm gettin' tired listing it all. The small stuff is good for hooks, make an upright mandrel, heat several inches at once in the forge, drop over the mandrel and pull. Instant straight stock! The larger is good for punches, small chisels, etc. Good neighbors Rock! Quote Link to comment Share on other sites More sharing options...
dkunkler Posted February 4, 2009 Share Posted February 4, 2009 I have used 3/8 spring stock for making flint strikers. Just forge ,harden, and temper. It will throw plenty of sparks. Quote Link to comment Share on other sites More sharing options...
markh Posted February 4, 2009 Share Posted February 4, 2009 I recently got a couple car springs. Does anyone have a safe method for removing the paint from them? I've considered taking the forge outside and burning the paint off during the first heat. Does that sound safe? Will the paint/powder coat materials contaminate my forge? Thanks Quote Link to comment Share on other sites More sharing options...
saintjohnbarleycorn Posted February 4, 2009 Share Posted February 4, 2009 the problem with burning it off is you are putting some pretty nasty stuff in the atmosphere that someone is going to have to breathe down the line, no easy solution there, wire brush is better I would guess, maybe some chemical would get it off, no good way. I have a lot of galvanized stuff and now wondering what to do with it. all my car springs are totally rusted and the paint long gone! kevin Quote Link to comment Share on other sites More sharing options...
Phil Patrick Posted February 5, 2009 Author Share Posted February 5, 2009 I know that on the market is an orange oil base paint stripper. I have never used it so I cannot vouch for it's effectiveness. Quote Link to comment Share on other sites More sharing options...
SLOB Posted February 5, 2009 Share Posted February 5, 2009 I've used the citrus (orange) based paint stripped on a couple projects. the last one being my latest anvil that had a HEAVY painted finish. (several heavy coats) it removed the paint quickly....the thicker area's needed a second application. I found spreading the gell on the surface then covering with a damp shop rag helped. it prevented the gell from drying while the citrus did its magic. I dont know how well it will work on the paint used on car springs, I have a feeling they are a powder coated paint......but I would say its worth a try. Quote Link to comment Share on other sites More sharing options...
