Steve Sells Posted January 17, 2009 Posted January 17, 2009 From Knife chat Jan 16,2009 [LDW] Is there a proper side to mark your knife? Whether its a touchmark or stencil. I have seen them on either side, but was wondering if there was a standard. [steve sells] totally I warranty is MY NAME, so I wont repair unless I am told to. I would prefer to replace it [markb] They should get your best work. Same as with any job coming out of the shop [steve sells] I do SLSELLS on one side with 1/16 stamp, and the other with Fenris Forge the forge name I have in 1/16 and 1/8 depending blade size so I use both actually [Finnr] on antler handles I scrimshaw my touch on the butt [steve sells] IF my son ever gets back in forge he will have his name, as well as fenris forge, when he is good enough: OK I stamp forge name on anything from my shop that I warranty. Also the maker name is there too on knife or camp set tools its as much a part of my advertising as the web site we all put a lot of work into our projects, we SHOULD put our names on it if we are ashamed to place our names, then it should NOT leave the shop [Finnr] everyone has an individual style, but that isn't advertising to people who don't know your style [markb] I would like to know how to get a good clean block letter stamp like HENRY as example [steve sells] I bought my stamps. using standard fonts is fairly cheap I paid 80 for my 3 stamps using THEIR font, if I wanted something else, it would have been about $120 each [m_brothers] from where, i've been looking for a place to get a John Martin Stamp Fromt [Finnr] for a name buying is the easiest my bindrune is simple enough that I made my own stamp [brucegodlesky] yep [markb] Stamp cold? [Finnr] Hot [markb] Could you post pic on forum? [steve sells] I stamp HOT red to black heat on final normalizing cycle before hardening [m_brothers] how do you polish up the name then? [steve sells] I though of a bind rune, but choose std english due to my non ren-fiar type work [Finnr] I'm going to do a new stamp as soon a I can work in the forge again I could do a BP while I make it [steve sells] you don't john, the name is inset deep into the steel I polish over the stamp maybe using a tooth brush to clean up later [Finnr] OK! I'll shoot pics [m_brothers] any place i could order from? [markb] Any etchers here? [LDW] I got a quote the other day for 135 dollars [steve sells] do a fast search around places before ya have one made because it would be a shame if you made one and found another maker using one that looks close [LDW] I etch [brucegodlesky] a name stamp? Buckeye Engraving [Finnr] only to bring up the pattern [markb] After finial finish? Steve sells] I got mine from CER Metal & Marking Corporation 2224 Industrial Drive Suite C, Highland,IN, 46322 (219)924-9710 they have a web site somewhere. [steve sells] chemical stamping most likely should be done when finished [Finnr] etch your name after mark? is that the question? [LDW] I built one of those etching machines that was on the web where you buy everything from radio shack. Now I want a stamp. [markb] etch would be that last thing? [Finnr] I would say so [markb] Press for stamp? [brucegodlesky] I do it by hand but it's tricky [steve sells] I didn't bother with a etch because of the pattern welded damascus I do it wouldn't show well, so got hot stamps made [Finnr] I hammer, but am thinking of using an arbor press for the new stamp [brucegodlesky] in the process op building a press [markb] Would a press be used hot or cold or ether [brucegodlesky] I would say either [Finnr] I like working hot [steve sells] I have seen makers use an engraver to make their marks, they just sign them [brucegodlesky] I have a jeweler do some for me. dirt cheap [markb] i have individual letter stamps a jig for these, yours not mine? [Finnr] with my handwriting a stamp is a better idea [brucegodlesky] usually 3-5 bucks apiece [brucegodlesky] I had one and he took ill, supposed to be back at it soon, probably with higher prices too [LDW] Batson did a demo on engraving at our conference a couple years ago. He made it look easy. [m_brothers] for John Martin, should it a line or John second line martin [Finnr] I want to learn, but there are only so many things a person can do [steve sells] your call, buy remember the larger/longer a stamp the harder to use it on small items [Fionnbharr (finn:-)] All complex things are a series of simple things combined in a specific process [markb] simple isn't always easy [brucegodlesky] I use 2 stamps. One is BIRDOG the other FORGE. The first for stock removal blades and both for forged Quote
markb Posted January 17, 2009 Posted January 17, 2009 I googled for stamps this morning and found this . I know there's got to be more?Tang and Knife Stamps Quote
brucegodlesky Posted January 17, 2009 Posted January 17, 2009 Do a seaerch for Buckeye Engraving, they're in Ohio and also Henry Evers Company? I believe that Riverside maxchine does them also. Quote
markb Posted January 17, 2009 Posted January 17, 2009 Thanks Bruce here they are:Henry A. Evers CoBuckeye Engraving Custom Steel Hand Stamps Guess I'll go get busy making a knife. Quote
brucegodlesky Posted January 17, 2009 Posted January 17, 2009 I've cold stamped perhaps 100 blades wqith my Buckeye stamp and it is as clear as the day I received it. Quote
markb Posted January 18, 2009 Posted January 18, 2009 Found itInfinity Stamps - Quality Steel Leather, Metal, Jewelry & Clay Hand Stamps Now i need to learn to make a blade worthy of a stamp. Thanks Mark Quote
MRobb Posted January 18, 2009 Posted January 18, 2009 I got mine from Infinity Stamps right after Christmas. Haven't had the chance to use them but a few times. So far so good. Quote
