January 7, 200917 yr No photograph is shown. I had this happen each time I tried posting a photograph that was larger then the web site allowed to be posted.
January 7, 200917 yr Your anvil looks great but that anvil base is absolutely grand. Did you bore the hole then burn it square? Do I see the burning iron on the ground to the left of the anvil?
January 7, 200917 yr An impressive bit of work on both the anvil and the stand. Love the spike to keep the anvil on the stand.
January 7, 200917 yr Author Drilled then made a mortice out of angle to cut square.Then used popane torch to burn out shavings. Thanks for all the complements appreciated
January 7, 200917 yr Author Anvil weighs around 30 pounds stand about the same. Thanks for the kind words
January 8, 200917 yr Author Thank you sir. I still have to put on all the handles and hardie staples along with the ground spikes.
