December 30, 200817 yr Hey, had a question and knew if anybody knew, you probably would. I have picked up a very rare 1988 turbo diesel Isuzu Trooper. Why are they rare? well first, you know about the failure of the diesels in the 80's because of smell and noise factor but most importantly, these came out of production because they had very weak rods. They would only last up to 100,000 miles, and a lot of times they wouldnt last 10,000 miles because the motor has a turbo and no rev limiter, blowing these little dudes apart because people revved them like gas engines. All of these were still under warranty when about 5,000 of these 50,000 sold started breaking rods. So, they did an upgrade, called it rod 3234. Generation 1 rods were casting 3066 if this matters to you at all... Well, some of these 2nd gen rods were breaking too, so they redesigned and beefed the heck out of them, strangely enough they also called them casting 3234. I have access to one remaining rod, possibly the only brand new one left on the planet. What is your price to manufacture 4 of them? They are forged steel.
December 30, 200817 yr Ed, show us photos of the rod you would like made. Give dimensions if possible.
December 30, 200817 yr It would be easy to forge the rods but I would hate to have to put a hole all the way through them so the oil can get through em'.
December 30, 200817 yr Why would Suzuki have Isuzu parts? Did they make the motors or buy the design from Isuzu? Connecting rods are pretty complicated to forge and machine, I have worked on some raw forgings. There is as much machining involved as forging and it HAS to be right. Getting the weights right (for each end of the rod) is important, so they need to be close to stock shape (usually an "I" beam). Most rods do not have oil holes, usually only large ones (Mack, Cummins, Etc.). I'd look into installing a different engine. Good Luck!
December 30, 200817 yr There are companies who make custom engine components and could very easily due so for you since you have a model for them to copy from, I would sugest you look into finding one of those companies, if you do a search on google you should be able to turn up something pretty easy. I have delt with companies and had custom pistons, pushrods, and some other misc. parts made that could not be bought off the shelf. welder19
December 31, 200817 yr With the amount of Diesel Isuzu small box trucks on the road i would be looking for a motor out of one. You may luck out and find it'll bolt right up to your trans.
December 31, 200817 yr now im not sure of this but they put the inline4 in a lot of reafer units and some one told me that the motors can interchange
