samw1 Posted December 30, 2008 Share Posted December 30, 2008 :confused:Hi all, im haveing problems with the final finish of what i make and have figured out whats not working thanks to everyones help. The reason why the things i make dont look good is because i dont brush enough and my stand is about and inch to low. well i easily fixed the first one and the stuff i make dosnet look pockety but it has all these ridges and odd dents from my hammer not hitting square. my problem is i cant readily get a stump for a stand and dont want to fab one becaus im switching anvils as soon as i can. so what should i do to make it so its level enough and i dont have a modle of mount everist on my finishe piece. :confused: Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted December 30, 2008 Share Posted December 30, 2008 plywood or 2x12 under the current stand ? Quote Link to comment Share on other sites More sharing options...
tech413 Posted December 30, 2008 Share Posted December 30, 2008 ^^^^^ That's what I would do. Quote Link to comment Share on other sites More sharing options...
jeremy k Posted December 30, 2008 Share Posted December 30, 2008 Use a 55 gal. drum cut down and filled with sand..... that way you can level the anvil as needed and it will adjust to any anvil - just another thought - JK Quote Link to comment Share on other sites More sharing options...
