ceramic compound
usabirddog
I don't know the proportions or seive (grain) size but ITC-100 is basically zirconia and kaolin clay.
If you start experimenting with your own mix keep careful notes including the results and please share with us. My bet though is you'll have spent many times as much as just buying a can before you get it right.
Frosty
  • 2 weeks later...
Refractory cement is available from a supply store for Bricks & Mortar. One of our members is a brick-layer and he buys a bucket when he gets his other supplies. He then sells/shares with our other members.
After you put the refractory in place and it dries, you have to put a VERY LOW HEAT inside to dry out the water. If the water expands into steam, you have a mess!!
another fine day above mother earth
Neil
viblacksmiths.com - Vancouver Island Blacksmiths Association
