larrynjr Posted December 9, 2008 Share Posted December 9, 2008 I read various references to using acid's to remove the flux and vaguely remember something about vinegar. Is vinegar strong enough to remove the flux residue or is there a commercial product I should be looking for? Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted December 9, 2008 Share Posted December 9, 2008 GET a butcher block wire brush farrier supply houses sell them wire brush hot when finished with weld Quote Link to comment Share on other sites More sharing options...
John B Posted December 9, 2008 Share Posted December 9, 2008 Boiling water will remove borax based flux, Quote Link to comment Share on other sites More sharing options...
Ice Czar Posted December 9, 2008 Share Posted December 9, 2008 (edited) I read various references to using acid's to remove the flux and vaguely remember something about vinegar. Is vinegar strong enough to remove the flux residue or is there a commercial product I should be looking for? like most any acid its the dwell time and the temperature dependent rate of chemical activity that would determine if it would do the job within a reasonable time frame Ive used alot of white vinegar and its a decent pickle (far less toxic than muriatic which is the other acid Ive used alot), what I havent done however is any forge welding so can't really address using it to strip borax chemically its considered a weak acid even within the carboxylic acid group I consider that an advantage (being cheaper and safer) Edited December 9, 2008 by Ice Czar Quote Link to comment Share on other sites More sharing options...
Thomas Dean Posted December 17, 2008 Share Posted December 17, 2008 I use 20 mule team Borax, have started mixing with silica, and with small parts and tight crevises even with a butcher block brush you will still have some residue in those little tight hard to get to places. Boiling hot water or hot vinegar seems to work pretty well. I have asked and hoping for some E-Z Weld for CHRISTmas!;) Quote Link to comment Share on other sites More sharing options...
