shanew8869 Posted November 27, 2008 Share Posted November 27, 2008 hey all, so when building my first forge im using a 2 inch flange to connect the firepot to the tuyere. problem being that the flange is galvanized. is this one part going to be an issue, or will the potential fumes be negligable? Quote Link to comment Share on other sites More sharing options...
nett Posted November 27, 2008 Share Posted November 27, 2008 (edited) Negligible if you first fire up the beast outside and stay downwind from the smoke, or you could dip the flange in diluted muriatic acid bath (swimming pool acid) to remove the zinc. POUR ACID INTO WATER NOT WATER INTO ACID. On edit: the zinc will be removed in a matter of minutes. Oh, it's a good idea to stand upwind from the acid bath because the pickle will generate strong fumes. ;) Edited November 27, 2008 by nett yes Quote Link to comment Share on other sites More sharing options...
shanew8869 Posted November 27, 2008 Author Share Posted November 27, 2008 thanks, i appreciate it. Quote Link to comment Share on other sites More sharing options...
Glenn Posted November 27, 2008 Share Posted November 27, 2008 stay downwind from the smoke, or (clip) to stand upwind from the acid bath because the pickle will generate strong fumes. STAY OUT OF THE FUMES no matter which way the wind direction. Put the galvanized part into vinegar (acid) to remove the zinc. When it is finished, you can neutralize any remaining vinegar on the part with a baking soda and water solution if you wish, or rinse the part well with water. Properly label the used vinegar so it can not mistaken for anything else, or kill the acid by neutralizing with baking soda and dispose of the solution in a safe manner. Quote Link to comment Share on other sites More sharing options...
Frosty Posted November 27, 2008 Share Posted November 27, 2008 Use vinegar, it'll take longer but it isn't hazardous and needs no special treatment to dispose of. Frosty Quote Link to comment Share on other sites More sharing options...
