Mike BR Posted January 20 Share Posted January 20 I worked out a new (to me, at least) way to cut a wide kerf with a hacksaw -- in this case to cut an internal keyway in a gear hub. First, I ganged two blades in the saw and cut a kerf to the appropriate depth. Then I took one of the blades out and reinstalled it upside-down (teeth toward the saw frame). I found a piece of sheet metal a little thinner than a hacksaw blade, cut an narrow shim, and placed it against one side of the kerf. Then I put the saw back in the kerf, with the reversed blade against the shim. The shim forced the live blade to cut beyond the edge of the existing cut; the reversed blade rode along the shim without destroying it. I went to a couple of progressively thicker shims until I got the kerf thickness I needed. It didn't do as neat a job as a keyway broach (If I could afford one of those), but I cut a keyway in about 10 minutes that I think would have taken close to an hour if I had to use files small enough to fit in the bore. Quote Link to comment Share on other sites More sharing options...
Frosty Posted January 20 Share Posted January 20 That'll work. Is a broach that hard to make? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
JHCC Posted January 21 Share Posted January 21 Mike, could you show us some photos or a sketch? Quote Link to comment Share on other sites More sharing options...
Mike BR Posted January 21 Author Share Posted January 21 I can't seem to find my earlier post -- hopefully that isn't a sign. But here are photos of: The ganged blades in the saw; the first kerf; the saw with one blade reversed; the saw with one blade reversed in the cut with a shim; and a shot of a partially completed second cut, where you can hopefully see how the tooth-down blade is widening the kerf on the right-hand side. Sorry for duplicate photos and poor organization -- can't figure out how to fix that. Mod note: we cleaned it up for you Quote Link to comment Share on other sites More sharing options...
Scott NC Posted January 22 Share Posted January 22 I learned a new technique. Thank you. This should also be in the "Tips-N-Tricks" section. Mod note: Moved. Thanks for the tip. Quote Link to comment Share on other sites More sharing options...
Frosty Posted January 24 Share Posted January 24 Pretty slick Mike, well done. I love adding new stuff to my mental tool kit. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
