Advice on buying a forge
I found a video of a fellow lighting and adjusting one of these online. It looks like a much better burner than the one you're using now. You might want to look around more before spending the money on one though.
Actually, the photo says it all; this will never be more than a second rate burner. Why? Because the pipe reducer being used as its conical shaped air intake does not even provide a two to one reduction in diameter with the inside of the pipe being used as the burner's mixing tube. You need at least a two and one half reduction in diameter for a linear burner to come alive, and a three to one reduction is desirable.
  • 1 year later...
On 11/2/2023 at 8:48 PM, OlavFairhair said:
Hei Olav.
Jeg er en likesinnet som planlegger å kjøpe en gass esse. Jeg bare lurer på om jeg kan få div råd av deg. Det er ikke mange smeder i Norge. Kan vi komme i kontakt? Send meg isåfall en sms på 99116166.
Hilsen Stian Jagedal
