August 12, 20232 yr Curious what people think of the condition of this Hay Budden, 170# (?), that's local to me in the north east. Markings are pretty worn, fairly rusty. Couldn't see serial but might have been there if I looked hard enough. What's it's worth? Thinking of going back and doing the ballbearing test.
August 12, 20232 yr Welcome from the Ozark Mountains. Just from the pictures I would say it's in very good shape. If it passes the ring & rebound test in my neck of the woods it would sell for US three to four dollars a pound. Of course that would depend upon not having the hardened steel face ground or milled down in the past. There should be a serial number on the front foot under the horn. I believe some prices in the NE run higher depending upon where. A wire wheel on an angle grinder will clean it up and a coat of BLO will keep it looking good. I can't control the wind, all I can do is adjust my sails.
August 12, 20232 yr Author Thanks for your feedback Edited August 12, 20232 yr by Mod30 Remove @name tag
August 12, 20232 yr Hi, Get a piece of chalk after removing rust and rub the sides. Will make the lettering stand out better. Opti Visors also help.
August 12, 20232 yr Author I went back and got about a 8 inch rebound dropped from 12 inches with a one inch ballbearing. Good ring.
August 13, 20232 yr If there was significant rust on the face, that may have dampened the rebound somewhat. Check the rebound again after you have wire brushed the rust off as best you can....NO GRINDING!
August 13, 20232 yr Author Thanks arkie, that was my thought with the rust and with it cleaned up maybe better rebound.
August 14, 20232 yr Looks like a horseshoers anvil. Nice one. Be good to it and it'll be good to you. George
August 14, 20232 yr Well, grab it as soon as you are able...Hay Buddens are a premium anvil. It won't last long on the market.
August 16, 20232 yr Go get it.. What you waiting for. Never mind the serial number.. Its a second gen since it's welded at the waist.. I'd go get it, if it was closer. 170+ lbs of goodness.
August 16, 20232 yr Congrats.. If you're new to forging. Don't beat it up in other words avoid hitting it with your hammers face or peen. . It's a piece of history and in Mint shape.. I've seen more really nice anvils beaten up by new smiths since this "Makers" boom has started.. No respect.. Treat that anvil like it's a milling machine, or table saw, or other high end piece of equipment or instrument. Besides it's a historical artifact.
August 16, 20232 yr Author I can appreciate that. I'm all about preserving artifacts and restoration including my 1910s home. I also got an 1850s Pennsylvania rifle made in Philadelphia bundled in a deal with the anvil. I'm in Philly suburbs and currently I'm over the moon!
August 16, 20232 yr If your in the Philly area.. Then the drive to Johnstown, PA is not that far.. ABANA 2024, I'll be there teaching, demonstrating and competing.. Glad to hear you will treating that anvil properly. If you are just starting out.. Few ground lessons.. When you work on tapers.. The taper goes over the far side of the anvil so the face of the hammer never has the chance to strike the anvil. Watch videos by Mark Aspery or go to my youtube channel.. Not the best quality of video but some really great info.
August 16, 20232 yr Author Thanks jlp! Yes been considering some lessons in near future. Will look into your suggestions!
August 16, 20232 yr Congratulations on being a new owner of a HB!....and the Pennsylvania rifle to boot!! What caliber is the rifle?
August 17, 20232 yr 8 hours ago, AnimaVetus said: I also got an 1850s Pennsylvania rifle made in Philadelphia bundled in a deal with the anvil. I'm in Philly suburbs We won't remember your location once leaving this post, hence the suggestion to add it in your profile. We have a subforum about old guns gunmsithing would love to see some pictures of yours here. https://www.iforgeiron.com/forum/214-gunsmithing-muskets-flintlocks-etc/ I can't control the wind, all I can do is adjust my sails.
August 17, 20232 yr Author Thanks irondragon. Will be sure to update my profile and post in the subforum. Arkie, good question. From research I'm thinking around .49 caliber, half-stock. I am picking them up in a few days. More info to come!
