jason0012 Posted May 4, 2023 Share Posted May 4, 2023 I have a plasma cutter I got cheap (really cheap) because it is three phase. ( it will run on single phase, but the guy who sold it too me did not realize that) it powers on and starts. I can even get the pilot to fire from the panel, but the gun won’t do anything. I put new consumables in it ( cost more than the machine) but I can’t get fire? Any idea what I should look at ( possibly a less questionable machine, yes it has occurred to me) This is one of the newer “rounded” chassis models and is by all appearances and reviews a fine machine, when it works… Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted May 4, 2023 Share Posted May 4, 2023 I googled it and the second one down is an instruction manual for pdf download. If you don't have it may help. I can't control the wind, all I can do is adjust my sails. ~ Semper Paratus Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted May 5, 2023 Share Posted May 5, 2023 Are you sure it will work properly on single phase? Quote Link to comment Share on other sites More sharing options...
jason0012 Posted May 5, 2023 Author Share Posted May 5, 2023 The book states that it will. I have it powered from a 240v 60 amp 3 phase line. The line is good, it is running my big miller mig welder. Quote Link to comment Share on other sites More sharing options...
Mike BR Posted May 5, 2023 Share Posted May 5, 2023 I found a thread on welding web with discussion of a similar problem and links to service manuals. It comes if you google ESAB PCM 875. Also, it looks like some parts of the machine are powered from two of the three input legs, so if you had the wrong leads connected to the single phase, it wouldn’t work (though I don’t know exactly what would go wrong). Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted May 5, 2023 Share Posted May 5, 2023 That's what I was thinking Mike, but he says its running on 3 legs Quote Link to comment Share on other sites More sharing options...
The Jeff Posted May 5, 2023 Share Posted May 5, 2023 Ok before I speak I have no experience with plasma cutters so if I'm wrong or way off feel free to let me know. But from what I am seeing if your consumables are good and connections are good you should check air? Not enough air or to much or contaminated? Again I don't know just trying be helpful. Quote Link to comment Share on other sites More sharing options...
Mike BR Posted May 5, 2023 Share Posted May 5, 2023 45 minutes ago, Steve Sells said: That's what I was thinking Mike, but he says its running on 3 legs Good point — I missed that. Quote Link to comment Share on other sites More sharing options...
