bubba682 Posted April 8, 2023 Share Posted April 8, 2023 Did a search can't match # to check age and weight i was just given this anvil it says patent on body but the name is rubbed out and 210 is punched into base the same as my 120 pound PW.Has anyone have an idea on age and weight i'm guessing over 200lbs on weight.. Quote Link to comment Share on other sites More sharing options...
Jason L Posted April 8, 2023 Share Posted April 8, 2023 you can take it to a local place that has a large set of scales. We used to weigh things like that all the time where I used to work. It was great for starting the conversation on where to get scrap iron or more blacksmith tools, even new customers. Try a scrap yard or farm store. They typically have scales that they don't mind using for heavy iron stuff and they usually have some strong backs around to do the lifting for you. The large truck scales sometimes aren't set up to measure in single pound instruments but they should have a scale large enough that will weigh give you a pretty accurate weight. Also pictures help A LOT! If you could take some pictures and post them you are much more likely to get a knowledgeable answer Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 8, 2023 Share Posted April 8, 2023 200+/- lbs is easy bathroom scale range. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted April 8, 2023 Share Posted April 8, 2023 Yep, a couple of strong back friends or a hoist and gently set it on the scale, weight confirmed or a new weight marking would be in order. Quote Link to comment Share on other sites More sharing options...
Jason L Posted April 9, 2023 Share Posted April 9, 2023 3 hours ago, Frosty said: 200+/- lbs is easy bathroom scale range. Frosty The Lucky. That's true but I'm not allowed to put anvils on my wife's bathroom scales so I had to use other means. She was afraid I would drop it and break or dent it or something I suppose. Quote Link to comment Share on other sites More sharing options...
bubba682 Posted April 9, 2023 Author Share Posted April 9, 2023 I break the wifes scale i'm dead lol i'll get some pics up shortly. Quote Link to comment Share on other sites More sharing options...
bubba682 Posted April 9, 2023 Author Share Posted April 9, 2023 The # is reversed in photo but its 210 the word is patent so whats the verdict Peter wright or something else. Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 9, 2023 Share Posted April 9, 2023 Don't hit garage / yard/rummage sales much do you? Pick one that has a lot of household . . . stuff and bathroom scales are common I avoid household and children's clothes yard, etc. sales but B'room scales were available at more than 3/5. Just weigh yourself before you hit the sales so you can check what you find. If you break her scale without dents or broken bits, don't say anything! When she says something you get to say it worked fine for you a couple hours earlier. WhatEVER you do NEVER tell her about the joke. Not until the well after the divorce or maybe leave a message in you estate papers. I wouldn't even then even if I were already dead. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted April 10, 2023 Share Posted April 10, 2023 The 210 is the anvils English stone weight (CWT) which relates to 252 pounds. Quote Link to comment Share on other sites More sharing options...
bubba682 Posted April 10, 2023 Author Share Posted April 10, 2023 Thxs Irondragon i wasn't sure on english stone weight and it wasn't the weight i was intrested in it was what the 210 meant in weight maybe i didn't word my ques right initially.To me in my limited experiance with PW anvils its a PW because of where the word patent is on the body what do you think is it a Peter Wright or am i wrong. Quote Link to comment Share on other sites More sharing options...
Stash Posted April 10, 2023 Share Posted April 10, 2023 The flats on he feet are a good indicator for PW. I'm thinking you have one. Steve Quote Link to comment Share on other sites More sharing options...
