Alex_22 Posted June 5 Share Posted June 5 M2 steel 1190 C 1 hr and 620 C double tempering for 2 hrs. Etched using 5% Ni for 3 min. Around 100 um white region with big grains at the outside of the materials, the hardness is 200 HV. The brown region hardness is 750 HV. What could be this soft white region with big grains? How should I reharden it? Thanks! Quote Link to comment Share on other sites More sharing options...
Irondragon ForgeClay Works Posted June 5 Share Posted June 5 Welcome from the Ozark mountains. If you put your general location in your profile you may have members close enough to visit. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 5 Share Posted June 5 I'd suggest consulting a professional metallurgist. M2 is not usually a steel blacksmiths have experience with! Quote Link to comment Share on other sites More sharing options...
velegski Posted June 6 Share Posted June 6 If this is for knife making you might try asking on some of the knife maker forums. While it not a common steel for knifes a Google search showed some of the Blade forums guys have used it Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted June 6 Share Posted June 6 but if it were about blades, wouldn't he have posted it in the HT knife section rather than general Quote Link to comment Share on other sites More sharing options...
patrick Posted Wednesday at 08:40 PM Share Posted Wednesday at 08:40 PM That is probably a region of decarbuization. That happens more rapidly in this grade than many more common blade steels. You can minimize it by packing the blade in carburizing compound during austenitizing. You can grind it off too. In theory you could recarburize the are that list carbon, but it is much simpler to prevent it from the beginning. Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted Wednesday at 11:50 PM Share Posted Wednesday at 11:50 PM OP has not returned since making this post Quote Link to comment Share on other sites More sharing options...
