Craigo Posted April 13, 2022 Share Posted April 13, 2022 Recently I purchased this hand crank forge as you can see it needs some work, hopefully it can be restored back to working condition. I would appreciate any advice on restoring it and also an identification would be awesome. Thank you in advance. What a great community. Regards Craig O Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted April 13, 2022 Share Posted April 13, 2022 It kinda resembles a foos scientific forge I’ve seen before, that being said there were several companies that made a table top forge Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted April 13, 2022 Share Posted April 13, 2022 It would help to know where in the world you are located, hence the suggestion to edit your profile to show location. Quote Link to comment Share on other sites More sharing options...
Craigo Posted April 14, 2022 Author Share Posted April 14, 2022 Hi I'm located in Australia, cheers. Craig I have had a google for the Foo forge and yes that looks like it : ) Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted April 14, 2022 Share Posted April 14, 2022 Welcome from the Ozark mountains. Have you seen this thread? A great bunch of folks there. OZ roll call - Everything Else - I Forge Iron Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted April 14, 2022 Share Posted April 14, 2022 Here’s a photo I found online not sure if it’s the same or not Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 14, 2022 Share Posted April 14, 2022 Small forges were often used in remote places like mining camps and sheep stations. Quote Link to comment Share on other sites More sharing options...
Farmall Posted April 15, 2022 Share Posted April 15, 2022 Here's mine. This is the day I got it. It was lined with cement. Quote Link to comment Share on other sites More sharing options...
Craigo Posted April 15, 2022 Author Share Posted April 15, 2022 Hey thanks so much sure does look like the one I have, any tips on how to restore one of these guys? Hi thanks just wondering if you got it working ok? any tips to restore one of these ? Cheers , Craig Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted April 15, 2022 Share Posted April 15, 2022 The first thing I do is to free up anything that is supposed to move by soaking it with a 50/50 mixture of acetone and automatic transmission fluid (Dexron III works best) the next best penetrating oil is Kroil. The main thing is to not force or hammer on anything, old cast iron is easy to break., patience pays off. It looks like your pan has clay/refractory in it. If so and it's in good condition I would leave it. The cast iron pans need to be lined to prevent cracking. Once everything is oiled up and turning smoothly, a wire brush will remove a lot of rust or spray/brush it good with a rust remover, I like Evapo-Rust. Check the blower fan blades, if any are missing or damaged it's pretty easy to make new ones. Also the belt is easy to make out of old leather belts that can be picked up at most thrift stores. Quote Link to comment Share on other sites More sharing options...
Craigo Posted April 15, 2022 Author Share Posted April 15, 2022 Hey thanks so much, this is a great help, I'm looking forward to putting up some pictures of the forge as restored. Cheers, Craig Quote Link to comment Share on other sites More sharing options...
