September 6, 20214 yr Author On 8/1/2021 at 10:03 AM, Adriaan Gerber said: I've hot pressed a 10" skillet in my 20 ton press in one go. A bearing race on the bottom with a round chunk of steel on top with some clearance. Finish with the hammer. If you could give some more info on what press you have and those dies, that would be awesome! Thanks
September 7, 20214 yr Author Simple, I like it! Obviously thats a pretty wide set of dies, what kind of press are you using? I'm thinking I'll need a large throated c frame press, almost the shape of a fly press, in order to fit the discs in Edited September 8, 20214 yr by Mod30 Remove excessive quote.
September 8, 20214 yr Author Given a 20 ton fly press can form these pans, I'm curious if one of those 20 ton H frame shop presses would work for this. I have my coal iron press for forging, so I wonder if getting one of these cheap hand cranked presses would work for forming the pan blanks
September 8, 20214 yr That’s the same one I have. Do you know what diameter the bearing race or the large round are? How much clearance is there between the two?
