Chris P Posted August 12, 2008 Share Posted August 12, 2008 Hi all, I'm finally getting around to doing a little body work on my truck and I'm very very new to welding. Not knowing that much about it, I'm a little concerned about different safety issues. I was wondering if it is necessary to remove the gas tank when welding the body of a vehicle? Any other tips or suggestions are greatly appreciated, but mostly I'm just concerned about 1) electrocuting myself and 2) blowing up the Scout. If it matters, I'm running a cheap generic 120 stick welder I got from Sears. Thanks a lot. Quote Link to comment Share on other sites More sharing options...
hdwarner Posted August 12, 2008 Share Posted August 12, 2008 i am a fan of ih can i see some pics Quote Link to comment Share on other sites More sharing options...
Thomas Dean Posted August 12, 2008 Share Posted August 12, 2008 How close are you going to be to the gas tank/lines? How much welding are you having to do? Sometimes it's better to er on the safe side, so if you have ANY doubts remove the tank. Also, welding automotive body parts with a stick welder is going to be a challenge, to say the least. If you can afford it, puchase a small MIG welder, or oxygen/acetalene rig and gas weld it. The wire (MIG) welding process is made for welding thin materials. If you have a friend that owns a wire machine rent it from him, or make a friend that has one. Good luck. would be fun to see before and after pictures....hint hint. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 12, 2008 Share Posted August 12, 2008 Do you need to weld or could you rivit the floor patch in? Quote Link to comment Share on other sites More sharing options...
Chris P Posted August 13, 2008 Author Share Posted August 13, 2008 here are a few pics of my two scouts. The yellow one is getting new floors and rockers. Actually I probably could have riveted in patches for the floors, or even left them alone for a while. But, the rockers are completely shot, so I figured I might as well do both. I'll snap some pics of the actual job tomorrow hopefully. Been raining so much here I can't do much of anything with them . Quote Link to comment Share on other sites More sharing options...
Awalker Posted August 14, 2008 Share Posted August 14, 2008 You might post on the Binder Bulletin or the Binder Bench. I have an 800 and have a lot of information on those sites. I would not remove the gas tank though, just make sure you are not cutting/welding right above the fuel line. Quote Link to comment Share on other sites More sharing options...
pigpen Posted September 20, 2008 Share Posted September 20, 2008 I don't know if I'm to late or not but it would be wise to unhook the battery before welding. If you don't you run the risk of shorting out anything electrical. Suth as radio computer fuelpump etc. Quote Link to comment Share on other sites More sharing options...
maddog Posted September 20, 2008 Share Posted September 20, 2008 Here's how its done! Quote Link to comment Share on other sites More sharing options...
Awalker Posted September 22, 2008 Share Posted September 22, 2008 Hey pigpen, that was the funniest thing I have heard in a while! A computer of electronic fuel pump in a Scout!:o Quote Link to comment Share on other sites More sharing options...
