Canister Damascus
Because the higher the carbon content the lower the melting/burning temp of steel. A mild steel canister can withstand a longer time in a hotter fire than it's contents and if it burns and loses carbon content it doesn't matter it's sacrificial you're going to cut or grind it off anyway.
A high carbon canister WILL decarb and possibly burn well before the steel inside can reach welding temps.
Make sense?
A large part of the canister's job is to isolate the contents from the atmosphere of the forge allowing you to make trickier welds or running a leaner/hotter burn if your forge is on the edge of producing forge welding temps when running rich.  As such it is sacrificial.
Al Pendray mentioned thermocycling wootz pucks a large number of times to get a decarb layer on the outside to make a "self canister" to work the extremely high C stuff in the center with out it cottage cheesing...
