1075 folded hatchet question
Recently I’ve been making some small (around 1 pound) folded hatchets that will be used for green wood spoon carving. Instead of using the normal method of forge welding a 5160 bit into a 1018 body, I’ve been experimenting with making the whole piece from 1075 that is forge welded to itself, which by the way it does very nicely. The reason for this unusual approach is that these are bearded axes and by using a single piece of steel it is possible to cut the initial template to shape with a nice long part for the bit. As you can see in the picture it sort of looks like a bow tie prior to folding. This unusual method again is in contrast to the traditional process in which there is a joint between a 1018 body and longer mid or high carbon steel bit that can be tricky to blend and dimension properly, especially on the lower part of the cheek/bit joint where the extended blade continues down. The long bearded example below on the lower right is a conventional 1018/5160 example.
What I’m noticing with this alternative 1075 method is that if I let it cool and then come back later to do some more forging to refine the shape there is a real tendency to develop cracks (5160 can be rather grumpy in this respect as well if hammered when not hot enough). This happens even when I’m being very careful to make sure the piece is fully heated (long soak at an orange color in the forge). Does the grain structure get radically altered in this steel when it is brought to forge welding heat? Will more careful and thorough normalizing prior to any additional forging alleviate this problem? Of course, one answer I guess is to do all my forging right at the time of forge welding.
* Note: I’m not a professional and these are just for use by me and students in my green woodworking tutorials. Have made about 20 hatchets to date of all different types and enjoy learning more about blacksmithing by trying new methods, although this one in particular may in the end simply not be a great idea.
Are you overheating it when forge welding it?  HC steels weld at lower temps than LC steels.  If it's spitting out sparks when you go to weld I'd bet it's overheated.
Using my three burner Whisper Daddy forge at about 15psi. Don't ever get spitting sparks, just some smoking, and in fact need to really be patient to get the heat up to bright yellow. In theory if I normalize for three cycles then the grain structure should be ok, right?
I realize that this use of 1075 for the whole hatchet is not necessarily economical or logical but the ability to precut the starting blank to a better bearded shape is appealing.
Instead of theory; TEST!
Have you done any where the bearded section was all HC steel forge welded into the body section?
Yup...testing is the next step. Just was surprised by the cracking given the heat I was working at.
And to date I've done 5 or 6 bearded axes with an all HC bit forge welded in. Blending the joint is the tricky part. I've been tapering the back side of the bit but only where it contacts the body of the axe. This is done in the manner typically used for an steel axe bit, meaning that I have been tapering it down and thinning the leading edge considerably. Moving forward I'll try rounding that edge but not tapering down too much because of the need for added material to blend in with the lower part of the curved cheek.
Shown here is my favorite hatchet along with the other tools I made to complete a greenwood spoon making kit:
It's a beauty.
For folks thinking about this sort of thing:   I know one typography of medieval blades was based on the type of weld between the WI body and the HC edge: (lap, butt, cleft, inverse cleft, etc). (Knives and Scabbards, Museum of London listed it as I recall based on a previous work.)
When welding an alloy that doesn't like to weld to itself, (usually due to Cr and Ni) I have sometimes used a thin piece of plain steel between them.  I scrounge *old* handsaws for this at the scrapyard---ones that predate the use of Cr and Ni in such sawblades.
one more thing to consider. Perhaps you are forging it below its forging temp. I don't have the specs for 1085, but I'd suggest not forging below 1500 degrees F
  • 1 month later...
the other thing can do since really a broad axe and a bearded ax are nearly the same. You can move your weld seam back to the mid point..
Are you putting the blades in to anneal in an ash bucket or just on the side of the forge?
Is it really cold in your shop?
By the way ideally the ends of the scarf should not be butted..  Not sure if I had seen it or not but I think you are butting them.
You should have  leading and trailing edge to work well.
Thanks Jennifer. I’m annealing in vermiculite but in hindsight I clearly need to more thoroughly normalize and anneal the 1075 if I let it cool down too much during forging. Don’t know if it’s the added magnesium that makes it a bit more brittle if not heated enough or just me bring a knucklehead! My bad....
By the way my shop is well heated and I definitely know about creating joints in forge welding that aren’t butted.
Here is a pair of my folded 1075 hatchets, the larger one is off to Alaska to my cousin who will use it to chop-up/dress moose in the field!
It is an 18oz head....really moves the wood efficiently for a hatchet. The weight feels very nicely distributed across the axe head and the whole tool feels very well balanced in the hand. In any event, I pity the poor Alaskan moose.....
The bat wing design with the curved lower profile Is something that very much appeals to my eye but it also can make drifting the eye a little tricky. Didn’t really have anything to hammer into or against that fit right. After some cogitating, a solution was found by making a modification to a swage block (I have several and this is a modern one, not antique). Specifically, I ground in the profile of that lower curve so that when drifting the eye the lower profile of the axe body is also being refined. Works great.
