Ed Steinkirchner Posted November 23, 2019 Share Posted November 23, 2019 The title says it all, had this project in the works for a while now and it's finally gotten to the point that it looks like something so i figured now it's the time to post some pics and details. It's built pretty much entirely from scrap, save for fasteners. The column is 8" well casing, capped with an 8" square of 1/2" plate, then the head is blocked 6" higher for the head mount on 4" pipe. The head itself is a 1 1/4" pipe with a heavily machined T on the end for the spindle. The spindle is mounted in tapered roller bearings, threaded at the nose 1" x 10 tpi for fittings like boring heads and fly cutters. More details to follow. The drive is going to be 4 step step pulley primary reduction, then a 2" to 6" final reduction to the spindle, which should make the bottom end speed with the 1725 rpm motor, about 200 rpm. The angle iron brackets that hold the head are bored to fit the horizontal pipe. They'll be split and fasteners added to clamp the head (it'll look like main bearing caps). Then the angle of the head can be turned left or right and clamped if needed. When the drive and the head is complete I'll add guards over the spindle pulley then it's on to the slide ways! Quote Link to comment Share on other sites More sharing options...
Ed Steinkirchner Posted July 29, 2020 Author Share Posted July 29, 2020 finally got this finished, added a cheap x/y table till i can make a better version, belt guard, paint, z axis, and built a cabinet with the surface plate in the top pull out drawer, plus everything else as far as basic accessories go. I know this isnt really a machining heavy forum but someone may find interest in seeing how a blacksmith builds a milling machine! final product with pretty much finished cabinet Quote Link to comment Share on other sites More sharing options...
Chris Williams Posted July 29, 2020 Share Posted July 29, 2020 Thanks for posting this. I admit that when I saw the first picture in your post from last year, I thought "What is this guy doing?" Of course, the next picture cleared it up. I'm no machinist, but would like to pick it up some day. Is it rigid enough to suit you? Quote Link to comment Share on other sites More sharing options...
Ed Steinkirchner Posted July 31, 2020 Author Share Posted July 31, 2020 its as rigid as a 3/4" spindle can reasonably be expected to be honestly. the bearings have about .0005 or so runout but thats peanuts for what i do. rigidity is very good in the head assembly but the table isn't made as well as i would like and I've spent a good deal of time removing backlash and defects. What I'm going to do is use this table (in addition to hand scraping) to bootstrap my way up to a better made system. At that point the x/y table will be sent to the drill press where its more suited to purpose. Honestly the whole thing was done as a practice project to help me hone my machining and machine building skills in a way that would yield something useful in the process. If i just wanted or needed a mill, buying one would really be a simpler way to go! Quote Link to comment Share on other sites More sharing options...
Chris Williams Posted July 31, 2020 Share Posted July 31, 2020 Thanks! Quote Link to comment Share on other sites More sharing options...
Scott NC Posted July 31, 2020 Share Posted July 31, 2020 That is a nice machine, Ed. Its very satisfying cutting metal on a tool you built yourself. I built Gingerys shaper many years ago and learned a lot from doing it. It lasted a long time but eventually fell apart and into the rolloff it went (minus a few MAPs). It bit me once in a careless moment so I wasnt too sad to see it go. Scott Quote Link to comment Share on other sites More sharing options...
Shellcrack Posted September 15, 2021 Share Posted September 15, 2021 Hi Ed, This is definitely an excellent build, superb! I am working on a similar design. Can you please provide some more info and photos on the spindle. Is it a tapered shaft or hollow pipe and is there a collet chuck at the end? Which type of cutting tools are you using? Any feedback would be appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
Ed Steinkirchner Posted September 26, 2021 Author Share Posted September 26, 2021 On 9/15/2021 at 8:32 AM, Shellcrack said: Hi Ed, This is definitely an excellent build, superb! I am working on a similar design. Can you please provide some more info and photos on the spindle. Is it a tapered shaft or hollow pipe and is there a collet chuck at the end? Which type of cutting tools are you using? Any feedback would be appreciated. Thanks! I don't have any progress pics of the spindle, but a description should suffice. the spindle is 3/4 inch OD bored through 5/16 for a drawbar to hold the homemade collets. The collets are 1'' major diameter and have a 10 degree taper down to 9/16 for the collet body. this limits my milling cutter shank diameter to right around 7/16 inch in the collets but thats more than reasonable for the light duty work i use it for. My most used endmills are 5/16 solid carbide roughing and finishing (because thats what my friend brings me when the cnc mills at work "wear them out" ) but i also use my flycutter a lot, which is just visible in the above pics and holds a 5/16 HSS toolbit. Im working on upgrading the head to something more rigid now, moving to a 1'' od spindle with a larger bore and larger collets, plus a more rigid fixation for the head to make it less likely to get out of tram. Quote Link to comment Share on other sites More sharing options...
