Manuel-Pagani Posted May 29, 2019 Share Posted May 29, 2019 Hi, I'm in the process of making a side blast forge and i want to share whith you. The design is based on Mark Aspery notes, the Main body is almost complete and now i'm working on the Hand Crank blower, inspired in a antique Buffalo flyweel design. Eveverything is Made of scrap ir recycled parts and materials. My idea is to use this coque forge whithout electricity, it will depend on the eficiency of the blower design, but whit the 60cm cast iron wheel driving a 2cm diámeter blower pulley plus the Crank relation of two turns of the flyweel per Crank i think it Will work.The main air tube is made big for this propouse from a 9cm Pipe narrowed at 2,6cm at the tip of the nozzle. What do you think? This post bring me back ti the forum since a long time, i will apressiate your suggestions and coments, i will go posting the progresess. I read in some other post about filling the botom of the forge whith different materials, i have on hand two: masonry sand or black soil (not a clay type) what did you recomend as a best option? Thanks and have a good forging day every body! Quote Link to comment Share on other sites More sharing options...
JHCC Posted May 29, 2019 Share Posted May 29, 2019 Looking good! I'd suggest masonry sand. That's what I have in mine, and it's working well (especially as it mixes with the coal ashes). Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 29, 2019 Share Posted May 29, 2019 Note that coke requires a constant blast or it tends to go out while you are at the anvil. Bituminous coal or charcoal will work better with a interrupted blast like hand powered blowers generally produce. Quote Link to comment Share on other sites More sharing options...
Manuel-Pagani Posted May 31, 2019 Author Share Posted May 31, 2019 On 5/29/2019 at 11:23 AM, ThomasPowers said: Thanks for the comments! today i'm Will make the first test whith sand filling and an electric blower Quote Link to comment Share on other sites More sharing options...
